Station Moved Country and Showing Wrong on LightningMaps
My station 1365 used to be located in Doha, Qatar, but I moved country a few years ago to Cyprus, and have resurrected the system and after giving the amp board a bit of TLC it appears to be working again on the test bench.
However, I have noticed that LightningMaps is continuing to show the station located in Qatar and not in its new location of Cyprus, Paphos, depending on which part of the site you are on.
I can't see any options to resync or force any update, so I assume that this will need to be done by admins.
Can someone help?
Thanks,
Dave
Stations: 1147, 1365
(2026-02-13, 07:37)Dave.Auld Wrote: Hello,
Can someone help?
Thanks,
Dave
Hi Dave... yes, the LMO database can be sluggish.... I updated the link in your signature... Is this what you were referring to?
Can someone help?
Thanks,
Dave
Oh... if you still control 1147, you desperately need to update the firmware... looks like it's way back 7.4 ... still running, but that's ancient....
https://docs.lightningmaps.org/station-o.../firmware/
[quote pid="27724" dateline="1770982752"]
[quote pid="27723" dateline="1770968266"]
[/quote]
[/quote]
Hi Mike, I was referring to the actual LigtningMaps website. as you can see in the attachment, it still shows the station in Doha.
Also, it shows the station twice on the MyStations List. (attachment 2)
And if I click on the station, it takes me to the station details where it still says Doha. (attachment 3)
 (as for my Aberdeen station, yes, well out of date and also think one of the channel on the amp is stopped working, need to look at it next time I'm back. I was back at Christmas for the first time in 3 years, and didn't have time to get round to it before heading back to Cyprus.)
Cheers,
Dave
(2026-02-14, 16:29)Dave.Auld Wrote: [quote pid="27724" dateline="1770982752"]
[/quote]
Cheers,
Dave
[/quote]
Ah.... gotcha.  Well, ahem... that's because LMO is not following the later main blitzortung databases well.  Tobi has to rebuild some areas of LightningMaps.org ... been an ongoing issue with data for awhile on the adjunct LightningMaps  since a server farm fire a few years ago, and extensive Blitzortung upgrades... All I can suggest is to note the disclaimer Tobi has on the site:
Ok, Gotcha.....no problem time will tell.
Thanks Mike.
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 14,491 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  Station not showing up tickertapes 5 26,031 2024-09-02, 11:25
Last Post: tickertapes
  station 3021 in https://www.lightningmaps.org jeanse 1 19,320 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 26,589 2024-08-07, 17:02
Last Post: mendip_defender
  Station 3012 in https://www.lightningmaps.org/ bakerkj 6 31,251 2024-04-16, 08:42
Last Post: jeanse
