Station 3012 in https://www.lightningmaps.org/
I was lucky enough to purchase station 3012. It was originally installed in Germany and is now in the US. Unfortunately the station still appears (in some respects) on https://www.lightningmaps.org/ as being in Germany. Is there someone here that can help update the data associated with my station to reflect where it is now?
Thanks so much!
-- Ken
Stations: 3012
Your 3012 is displaying on LMO... However, the LMO database still associates the station's 'sister' 3011 at the original user (I suspect) in Germany, with your user number. And vice versa.  Perhaps because they have not removed 3012 from their Operator's Page... 3012 IS assigned to your 'User Number', but also crossed with the 'previous' owner.   The database at LMO doesn't always follow the main Blitzortung updates, and Tobi MAY have to fix that manually.
Question:
Have you configured your station on your Blitzortung Operator's page?
If you DON'T have your operator's credentials, follow instructions there.
Suggest strongly that you also update your firmware to the latest: 10.5b1
Though 'beta' release, it fixes several glitches, and incorporates some much needed new features.
https://forum.blitzortung.org/showthread.php?tid=3789
Make SURE you download the "BLUE" firmware, NOT 'red'.
I'm upgrading your Forum permissions to "Participant".
Welcome Aboard!
Thanks Cutty!!
(2024-01-13, 23:34)cutty Wrote: Your 3012 is displaying on LMO... However, the LMO database still associates the station's 'sister' 3011 at the original user (I suspect) in Germany, with your user number. And vice versa.  Perhaps because they have not removed 3012 from their Operator's Page... 3012 IS assigned to your 'User Number', but also crossed with the 'previous' owner.   The database at LMO doesn't always follow the main Blitzortung updates, and Tobi MAY have to fix that manually.
@Tobi is this something you could help me with?
(2024-01-13, 23:34)cutty Wrote: Have you configured your station on your Blitzortung Operator's page?
yep - I logged in and configured my operator page.
(2024-01-13, 23:34)cutty Wrote: Suggest strongly that you also update your firmware to the latest: 10.5b1
I'll give it a shot!
(2024-01-13, 23:34)cutty Wrote: I'm upgrading your Forum permissions to "Participant".
Welcome Aboard!
Thanks again Mike!
Stations: 3012
I'm running 10.0b1 now
Stations: 3012
I deleted the old station from the database.
I'm sorry about the wrong data. The station data on Lightningmaps is just not usable any more. The reasons for that are the server burning, wrong data from Blitzortung import and other problems. The code is still based on my completely outdated MyBlitzortung scripts. It just doesn't make sense for me to put any effort in repairing this. Instead there will be a complete rewrite sooner or later. I just hope it will be this year. Big Grin
(2024-01-18, 11:36)Tobi Wrote: I deleted the old station from the database.
Thank you @Tobi!!
Stations: 3012
Hello to you.
I have a bit of the same problem with my 3021 station. I can't see these performances appear correctly on the lightningmaps site.
it's also a station that I just bought second hand, I already have another red 2421 station.
thank you all
Jean-Sébastien
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 10,376 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 16,215 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 20,482 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 19,904 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 14,743 2024-07-01, 07:29
Last Post: Blubbel
