(2017-09-05, 14:33)readbueno Wrote: After doing some tests with a multimeter. It appears C430 is now a short circuit and L403 is now open circuit, R405, the closest path to ground still reads 82 ohms?
My test equipment, little experience with failures in SMD parts and lack of replacements for these components doesn't permit me to come to any further conclusions at present.
Something has caused C430 to fail and it appears that L403 has acted as a fuse?
I will try to get replacements as quickly as possible and hope that not too much else is damaged.
Obviously, without L403 there is no power to the amplifier for the E antenna. Therefore no signals!
Any suggestions gratefully accepted.
Brian.
Brian,
I was just studying the schematic. Here are a couple of thoughts.
If the coax between the two boards was shorted, that would blow L403.
Same thing if the E-field board was shorted.
As for C430, perhaps a HV spike from the E-field board?
RE: Problem after updating firmware. blue 8.32b - by mwaters - 2017-09-06, 21:39
  9.4 Blue 19.3 Board Can't update firmware ni5f 6 19,705 2025-03-11, 13:53
Last Post: ni5f
  Firmware 10 on System Red PCB 10.5 - firmware bug ??? mmlightning 1 13,747 2025-02-27, 08:37
  System Blue GPS problem Steve- 12 85,945 2016-11-15, 09:35
Last Post: DnH2016
