Firmware 10 on System Red PCB 10.5 - firmware bug ???
I installed the new firmware on my PCB 10.5 controller for System red. The PCB was manufactured according to schematic and Eagle-File:https://docs.lightningmaps.org/files/hardware/red/PCB_10_5.brd
The firmware did not work properly as the PCB-ID was not detectected correctly. It turned out that PCB 10.5 has a different coding then described.
Description according to the hardware reference in TablePCB Controller Ids:
 https://docs.lightningmaps.org/hardware/...system-red
Id PCB System PD10 PD11 PD3 PD1 Offset
2 10.5   RED      -        +        -       -      0
but it turned out that actually Coding of PCB 10.4 and PCB 10.5 is different, PCB10.5 has the following coding:
? 10.5  RED      +        +        -       -       0
this can also be seen in the schematic of PCB 10.5,  so PD10 has a high level +5V  instead of GND like PCB 10.4.
I did cut off pin PD10 from the controller-board and now all is working; PCB 10.5 is detected as PCB10.4 now
... but it seems that there is a firmware bug in 10 RED ???? This potentially could affect several stations, as station list has decreased since new firmware is out
Sorry for my late reply after 8 months. I checked the firmware and every documentation I could find and I think there could be only this explanation: On the original PCB 10.5 the PCB id was accidentally the same as 10.4. The downloadable schematics/layout must have been altered and use the correct PCB id 3. It seems those PCBs were never produced/shipped by Egon, so I never added the id to the firmware.
I will add id 3 to the next firmware so the hardware doesn't have to be modified.
@mmlightning: Thanks a lot for the hint!
  Firmware Download not possible AHoh78 3 18,375 2025-06-13, 13:19
Last Post: Toxic
  9.4 Blue 19.3 Board Can't update firmware ni5f 6 19,708 2025-03-11, 13:53
Last Post: ni5f
  System Green PCB eagle Autodesk files meteolab 0 10,868 2025-01-26, 18:00
Last Post: meteolab
  Ethernet speed connection 10/100 on PCB 19.5 lyova 6 43,325 2020-03-07, 22:12
Last Post: mwaters
  System Blue PCB 19.4 vs 20.6 dhitzigrath 6 53,253 2019-11-22, 04:48
Last Post: kevinmcc
