build log [Blue PCB 20.5]
hello, just got my station.
==ordering==
1 x main board
2 x ferrite antennas.
+ shipping
+ paypal
total 235.84 €
==box==
content [pic]
* PCB 20.5
** pic
** schematics[1]
** board[1]
* two ferrite antennas
* thru hole components
content arrived with no issues in carton box (10x24x17cm) with some newspaper as filling.
pcb was inside a zip bag, the pcb sharp corners tore through the plastic bag and were exposed.
the kit didn't come with the 3mm LEDs, luckily i ordered a LED kit a while ago.
there are built in smd leds, which i failed to notice. the holes are to connect to an external led.
==soldering==
i started soldering with my chinese soldering station but i felt it didn't have enough power for handling the F/SMA connectors.
even the ethernet grounds gave it a fight. so switched to the metcal SP-200 with a fat head. it handled the rest well. with a bit of flux for some.
i sent my "finished" board picture to @tonuonu (who nudged me into blitzortung) and i noticed i switched the ethernet and mcu crystals.
[Image: fhRiom7.png]
so i had to do a little rework.
first blink!
==power==
Quote:"The main board is supplied with a 5V USB power adapter. The plug must be a USB-B Mini 5 pin. The power supply is not part of the kit. It must be purchased separately. The power consumption is about 450mA. Please use a 1A or bigger power supply. We have made bad experiences with 500mA power supplies."
first test with a power bank and a "usb doctor"
[Image: jqJeyBg.png]
==GPS==
Quote:You can use any GPS antenna operating with 3.5 Volts. The Antenna is connected via an SMA connector with the main board. The built in GPS module is very sensitive and works with antennas connected by lines of up to 10 meters.
==first boot==
on first boot and after connecting GPS and ethernet i got DHCP address and encountered the "PCB Unknown" error.
[Image: 07r1iff.png]
updated firmware to blue 8.3 from the firmware page. dont forget to actually click the "start update"...
[Image: QUmVpuH.png]
==antenna==
i got 2 ferrite antennas in my order.
Quote:4.1.2 Ferrite rod antennas
It is not necessary to align the two antennas to north/south and west/east. The antennas only have to be placed horizontally
[...] strip the insulation of the copper enameled wires, before the blank copper wires can be soldered to the amplifier board.
[...] one of the two copper enameled wire ends has a knot. Connect these wires with the positive inputs of your amplifier and the other wire with the negative input of the amplifier
instead of soldering the Ferrite wire to the amp board (PCB16) i burnt the ends and crimped it.
[Image: CQHzAwd.png]
[Image: KJF38Ju.jpg]
[Image: 4W6pbSS.png]
==result==
station 2075 is on.
[Image: IM7wfGA.png]
image gallery -> https://photos.app.goo.gl/iiSJuowBvufX85HH2
[1] both missing from http://www.blitzortung.org/Compendium/Hardware/, latest capture PCB_20_3 but it is different
[reserved] for further updates
Smile Welcome to Blitzortung! Smile
Nice Pictures.
Brian 1856. Smile
Does the new boards GPS modules have Galileo working?
i switched "experimental gallio mode" on and it feels like totally messed my station.
has status interface and gps errors
why galileo support?
i will try to stabilize the station and not mess with it as it seems to be in good standing
http://en.blitzortung.org/station_list.p...mbers=2075
(2017-12-16, 23:22)yair Wrote: why galileo support?
Galileo is new European GPS system and much more accurate.
Support for GPS, Galileo, and Glonass should help with those that have limited view of the sky and use all three to find a position.
Galileo being more accurate than GPS, 1m vs 5m, that may be helpful. I am not sure about timing accuracy.
Off topic here, but some information regarding Galileo: It may improve the position accuracy, but that's not important for our purpose. It doesn't significantly improve the timing accuracy (1PPS pulse). It could even make it worse. The module on the PCB will never be shipped with a Galileo enabled. This is only possible via special beta firmware for the GNSS module.
  System Blue PCB 19.4 vs 20.6 dhitzigrath 6 53,879 2019-11-22, 04:48
Last Post: kevinmcc
  H-field PCB 16.x sys Blue EricJ 4 40,323 2016-09-04, 13:50
Last Post: RichoAnd
