LightningMaps.org: Real-time Lightning Map
#34
(2014-05-30, 19:58)HamelGre Wrote: I tried FF (29.0.1) "New Private Window" and it landed roughly centered on the Northern tip of Denmark.
Then I tried IE (11.0.8) "In Private" and it landed centered roughly on the Poland/Belarus border.
You are right, it didn't work due to server-side caching of this page. It should work now, unless using IPv6 (supported soon).
(2014-05-30, 21:34)Cutty Wrote: Fine here with IE 10,11 and latest FF...
except... IE shows no Full Screen button , and of course won't go full screen. FF is fine, if a bit slower than IE. Cookies work as explained by Tobi on both browsers, unless I clear them.
The full screen mode is implemented as described in the documentation for each browser platform, but so far I didn't find the reason why it's not working in IE. For best speed, you should use Chrome.
Messages In This Thread
RE: Real time Lightning Map - by RichoAnd - 2014-05-09, 18:32
RE: Real time Lightning Map - by cutty - 2014-05-09, 19:59
RE: Real time Lightning Map - by scilover - 2020-06-03, 10:54
RE: Real time Lightning Map - by Dale.Reid - 2014-05-09, 20:55
RE: Real time Lightning Map - by Tobi - 2014-05-09, 21:12
RE: Real-time Lightning Map - by cutty - 2014-05-09, 22:16
RE: Real-time Lightning Map - by John.Sacrey - 2014-05-09, 23:56
RE: Real-time Lightning Map - by Tobi - 2014-05-10, 16:21
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-11, 00:46
RE: Real-time Lightning Map - by cutty - 2014-05-11, 01:21
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-11, 03:22
RE: Real-time Lightning Map - by robo - 2014-05-11, 12:11
RE: Real-time Lightning Map - by aib - 2014-05-11, 12:24
RE: Real-time Lightning Map - by cutty - 2018-12-16, 17:05
RE: Real-time Lightning Map - by Tobi - 2014-05-11, 17:32
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-11, 18:54
RE: Real-time Lightning Map - by Tobi - 2014-05-11, 19:47
RE: Real-time Lightning Map - by weatherc - 2014-05-12, 09:36
RE: Real-time Lightning Map - by Tobi - 2014-05-15, 20:50
RE: Real-time Lightning Map - by weatherc - 2014-05-15, 21:21
RE: Real-time Lightning Map - by Tobi - 2014-05-16, 17:54
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-17, 00:15
RE: Real-time Lightning Map - by saschaa - 2014-05-18, 18:42
RE: Real-time Lightning Map - by DelandeC - 2014-05-20, 17:22
RE: Real-time Lightning Map - by Tobi - 2014-05-20, 21:18
RE: Real-time Lightning Map - by DelandeC - 2014-05-21, 09:07
RE: Real-time Lightning Map - by steelek - 2014-05-24, 15:48
RE: Real-time Lightning Map - by cutty - 2014-05-24, 15:50
RE: Real-time Lightning Map - by HamelGre - 2014-05-30, 12:36
RE: Real-time Lightning Map - by Tobi - 2014-05-30, 17:22
RE: Real-time Lightning Map - by HamelGre - 2014-05-30, 19:58
RE: Real-time Lightning Map - by cutty - 2014-05-30, 21:34
RE: Real-time Lightning Map - by Tobi - 2014-05-31, 06:37
RE: Real-time Lightning Map - by HamelGre - 2014-05-31, 11:19
RE: Real-time Lightning Map - by zalama - 2014-06-07, 13:04
RE: Real-time Lightning Map - by mabro - 2014-06-07, 13:39
RE: Real-time Lightning Map - by Knickohr - 2014-06-07, 14:09
RE: Real-time Lightning Map - by Tobi - 2014-06-07, 14:51
RE: Real-time Lightning Map - by zalama - 2014-06-08, 05:29
Real-time Lightning Map - by NosDE - 2014-06-09, 20:08
RE: Real-time Lightning Map - by Tobi - 2014-06-10, 10:14
RE: Real-time Lightning Map - by weatherc - 2014-06-10, 12:29
Real-time Lightning Map - by NosDE - 2014-06-10, 10:39
Real-time Lightning Map - by NosDE - 2014-06-10, 12:40
RE: Real-time Lightning Map - by Tobi - 2014-06-10, 18:17
RE: Real-time Lightning Map - by weatherc - 2014-06-11, 14:22
RE: Real-time Lightning Map - by Tobi - 2014-06-11, 18:19
Real-time Lightning Map - by NosDE - 2014-06-11, 19:29
RE: Real-time Lightning Map - by Tobi - 2014-06-11, 19:51
Real-time Lightning Map - by NosDE - 2014-06-11, 21:45
RE: Real-time Lightning Map - by W3DRM - 2014-06-14, 21:29
RE: Real-time Lightning Map - by cutty - 2014-06-14, 21:39
RE: Real-time Lightning Map - by W3DRM - 2014-06-14, 21:45
RE: Real-time Lightning Map - by Tobi - 2014-06-14, 21:53
RE: Real-time Lightning Map - by W3DRM - 2014-06-14, 21:59
Real-time Lightning Map - by NosDE - 2014-06-14, 22:02
RE: Real-time Lightning Map - by Tobi - 2014-06-20, 15:44
RE: Real-time Lightning Map - by AleT - 2014-07-25, 13:27
RE: Real-time Lightning Map - by HamelGre - 2014-06-21, 13:10
RE: Real-time Lightning Map - by Tobi - 2014-06-21, 13:45
RE: Real-time Lightning Map - by ecreif - 2014-06-23, 14:56
RE: Real-time Lightning Map - by wxrman - 2014-06-26, 00:50
RE: Real-time Lightning Map - by jade - 2014-06-26, 04:21
RE: Real-time Lightning Map - by jumpjack - 2014-06-26, 12:25
RE: Real-time Lightning Map - by Tobi - 2014-06-26, 17:57
RE: Real-time Lightning Map - by cutty - 2014-06-26, 18:17
RE: Real-time Lightning Map - by weatherc - 2014-07-13, 13:43
RE: Real-time Lightning Map - by Tobi - 2014-07-13, 15:25
RE: Real-time Lightning Map - by Knickohr - 2014-07-13, 15:50
RE: Real-time Lightning Map - by Tobi - 2014-07-13, 17:47
RE: Real-time Lightning Map - by Knickohr - 2014-07-13, 17:53
RE: Real-time Lightning Map - by HolzHaus - 2014-07-14, 23:29
RE: Real-time Lightning Map - by Tobi - 2014-07-16, 10:47
RE: Real-time Lightning Map - by HolzHaus - 2014-07-16, 11:24
RE: Real-time Lightning Map - by cutty - 2014-07-14, 23:31
RE: Real-time Lightning Map - by Tobi - 2014-07-16, 18:22
RE: Real-time Lightning Map - by ari.jasberg - 2014-07-19, 14:54
R: RE: Real-time Lightning Map - by jumpjack - 2014-07-20, 08:20
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 14,233 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 19,050 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 26,011 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 23,931 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 16,565 2024-07-01, 07:29
Last Post: Blubbel
Users browsing this thread: 13 Guest(s)
