station 3021 in https://www.lightningmaps.org
Hello I have just purchased a second hand blue station in addition to my red 2421 and I cannot get the data on the lightningmaps.org site, it switches to the data of my red.
And second point more hardwear, I I have channel 1C which doesn't seem to work (I changed the cable between the amp: it's the same thing and changing the ferite same thing) does anyone have an idea?
Many thanks
Jean-Sébastien station 2421, 3021
Hi Jean-Sébastien
1) Unfortunatelly is LMO not maintained since a while. I think I read that Tobi needs to rebuild the entire website - as time permits.
2) Something is wrong with your user status. Your name should be displayed in green if you are the user 1975. Maybe someone with the rights could verify the user status.
3) According to https://map.blitzortung.org/statistic_0....nsparent=1 the blue station 3021 sends signals for all 4 channels.
Regards Klaus
  Station Moved Country and Showing Wrong on LightningMaps Dave.Auld 5 5,885 2026-02-14, 21:27
Last Post: Dave.Auld
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 14,216 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 25,982 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 23,895 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 16,546 2024-07-01, 07:29
Last Post: Blubbel
