Throughole components - partlist (Blue Basic 22.2b/c 23.1)
Hi guys,
with my last PCB order i decided to add the System Blue Basic 22.2b with Piggyback 22.2c and Preamp 23.1.
Adding the official partlist from the directory to my last Digikey order worked like a charm.
Except one thing: the throughole components are not in there Sad All of them are more or less easy to identify on the pictures, but i got one simple problem.
Which quarz oscillators 8 / 25MHz do i have to use - the CL (or Belastungskapazität) on the board is 10pF, everything else results in a slightly lower or higher frequency. What about the capacity of the tracks etc., do i have to pay attention at them?
That would lead to a quarz with a CL > 10pF
As the system should be used for participation later on, i'd like to have all values as close as possible to the "detector kit".
I'd also buy a "throughole component kit" (as seen on the picture on limaps org hardware ) if that is the easier way Smile
Cheers, 73 & 77 de Stefan, DD1SB
  air-core loop connection to H-field preamplifier 23.1 GeezerD 2 19,524 2025-10-16, 07:54
Last Post: merc82
  Partlist for system red lvrenml 1 16,088 2025-06-11, 08:25
Last Post: Helengrace
