Threads: 5
Hi.
I registered on Blitzortung.org, but i didn't received the email confirmation, i don't know if is because is the same email that i use for forum.
How many hours i have to wait to receive the email?
Threads: 10
Can you elaborate for what you registered ?
Threads: 10
2021-07-25, 18:22
(This post was last modified: 2021-07-25, 18:23 by NHSA_Rainer.)
Hi José,
It looks like your station is active.
You mentioned somewhere you live in Ciudad Guayana, Venezuela. I searched in the Blitzortung.org and found a station with number #2934
See attached images
Now you just need to watch your station and then learn how to optimize it.
Saludos Rainer
Threads: 5
Thanks, the station is registered.
Now i´m testing the antennas.
Threads: 10
(2021-07-25, 20:14)josecmorales Wrote: Thanks, the station is registered.
Hola José,
Do not forget to add correctly the antenna specification.
For doing that you need to go into the page
https://www.blitzortung.org/en/live_ligh...php?map=30
Log in and define your antennas here
and on the bottom of that page click on save
saludos Rainer
