Threads: 1
I recently took receipt of the system blue. We hope to have it up and running before the snow flys. I do have a question or two. I registered for the forum. Do I need to register anywhere else as a user once the system blue gets operational? If so, where do I do that?
Thanks in advance
L. Merry
Threads: 45
(2018-09-17, 17:44)BerkshireCC Wrote: I recently took receipt of the system blue. We hope to have it up and running before the snow flys. I do have a question or two. I registered for the forum. Do I need to register anywhere else as a user once the system blue gets operational? If so, where do I do that?
Yes, once you have it running, you will see your User ID on the Status page. Click on that and login. Enter your User-ID (which must be kept private) and your other station info there and save it. Once the BT servers start receiving signals, you're good to go!
I think the most up-to-date documentation is on
the new Wiki here. However, there is good information that you won't find there right here in the forum.
Threads: 35
Thanks in advance
L. Merry
Hi L.
follow this description here:
https://docs.lightningmaps.org/doku.php?...on:account
I hope this works. Feedback and correction is welcome.
Klaus
