Threads: 1
I am new, I just got the blue kit.
The ferrite antenna has two bare copper wires. One wire has an overhand knot, I assume it is to signify that wire is different from the non knotted wire.
Does it make any difference which wire goes to solder pad +1 and which goes to solder pad -1? I read elsewhere that the loop antennas can be attached either way so I think these probably don't matter either.
Concerning the GPS antenna, does it make any difference whether the antenna is amplified or not? I have ordered one with 25db gain.
https://www.amazon.com/gp/product/B01KDH...UTF8&psc=1
but it is inexpensive and I can get another if preferable.
Thanks.
David
Threads: 5
2018-09-11, 20:32
(This post was last modified: 2018-09-11, 20:35 by dupreezd.)
(2018-09-11, 18:21)de37421 Wrote: I am new, I just got the blue kit.
Concerning the GPS antenna, does it make any difference whether the antenna is amplified or not? I have ordered one with 25db gain. https://www.amazon.com/gp/product/B01KDH...UTF8&psc=1
Thanks.
David
David, first, congratulations on getting your system, let the fun begin.
It does not matter which ferrite wire goes where. Most of us put the knotted wire on the + terminal. This way after some experimentation you know from which direction the strokes come from.
As for the GPS antenna, I don't think an amplified one will work, but I might be wrong. You need to provide power to the antenna. I had a look at the schematics and it does not appear that the GPS IC provides power.
This is the one I am using
https://www.amazon.com/gp/product/B005RU...UTF8&psc=1
Threads: 18
There is power on the GPS antenna socket. I think all GPS antennas need power to bring the incredibly low level signals from the satellites up to a level that'll get along a few yards of coax cable. On the GPS module Pin 3 VANT is connect to the +3.3 V rail and internally to pin 1 ANTENNA IN.
I'm using one of the cheap GPS antennas underneath a slate roof without any issues. Currently:
100% availabilty, 18 tracked, 20 in view, 10 GLONASS.
1627
Threads: 5
(2018-09-11, 21:13)allsorts Wrote: There is power on the GPS antenna socket. I think all GPS antennas need power to bring the incredibly low level signals from the satellites up to a level that'll get along a few yards of coax cable. On the GPS module Pin 3 VANT is connect to the +3.3 V rail and internally to pin 1 ANTENNA IN.
I checked the Gmm-g3 datasheet and yes, you are right. Thanks for the correction.
Dries
