2018-01-23, 01:19
I would like to know if you can use a bolted lightning detector and if not can you tell me if you can get your equipment pre-built
Thanks
Thanks
Newbie question
2018-01-23, 01:19
Thanks
2018-01-23, 01:57
(2018-01-23, 01:19)Hkibler Wrote: I would like to know if you can use a bolted lightning detector and if not can you tell me if you can get your equipment pre-built No Boltek is a different system. For the second part of your question, please see: https://docs.google.com/document/d/1KzPZ...1516672436 There is some assembly required. This is NOT a 'Plug and Play" system... much more is involved than just turning it on. "...primarily aimed to individuals with an interest in meteorology and competencies in electrical and computer engineering. For the construction and operation of a lightning detector a basic understanding of the used reception technique is necessary."http://en.blitzortung.org/cover_your_area.php |
« Next Oldest | Next Newest »
| Possibly Related Threads… | |||||
| Thread | Author | Replies | Views | Last Post | |
| Newbie wants to contact a nearby Member | Moonbouncer | 4 | 41,526 |
2018-10-29, 00:08 Last Post: cutty |
| I'm a newbie | stevewhite257 | 2 | 25,541 |
2018-05-27, 23:31 Last Post: allsorts |
