Threads: 16
Question, when I'm search in the history I'm getting on every signal this message.
I have update all the files but with the same problem.
What can be the problem?
Let me know it.
Thumbnail(s)
Threads: 78
This behavior is normal. Signals older than 90 minutes must be deleted from the server due to space limitations.
Threads: 16
I have this error even when the strike is +/- 30min ago.
Strike at screenshot is from today 14:29 and it's now 30min later.
Thumbnail(s)
Threads: 73
Which version of MyBo do you use?
I think there are some fixes for that in the latest version.
Threads: 16
I use at this moment version 1.3.
Threads: 73
Try the update to 1.4-dev:
MyBlitzortung-master.zip
Just overwrite the files by uploading the new ones. Then go in your user area and choose "update database".
Backup your current installation before proceed the update.
Threads: 16
Thanks for the link, i will try this one.
Mabye an strange question, is there someplace where i can see what files there are changed?
Because i have made also on the current version some modifications.
Threads: 16
I have install this version and it's almost good running.
Except the first colomn that give an 25067 error about the scale, but i have nothing change about it (it's default from file).
Thumbnail(s)
