Lightningmaps.org history zoom
The Europe view on lightningmaps.org doesn't show any strikes if zoomed in. You used to be able to do this fine. Does anyone know a fix?
It appears to be working as designed... perhaps it may be your 'display' time settings on the page... for example, if you only have "2-24 hours' ticked, and
there were no strikes within that 'zoomed' area within the last 2 hours, there'll be no strike display.  Likewise, if only "0-15minutes" is ticked,  strikes older than 15 minutes will not be displayed...
or if only "15 minutes -120 minutes" is ticked,  "only strikes between 15 minutes and 2 hours of age" will display, not <15 or >120
etc... in combinations, etc.  to see  all strikes from "now (0 minutes) to last 24 hours, check all, and suggest check auto update also.
When zoomed out there are loads of strikes but they disapear when I zoom in, even though when zoomed out it says there are strikes in that area.
*Edit: It's Working Now
(2015-07-04, 13:05)lintup Wrote: When zoomed out there are loads of strikes but they disapear when I zoom in, even though when zoomed out it says there are strikes in that area.
Great!... guess the server must have taken a 'deep breath' for a while Big Grin
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 0 1,367 2025-05-02, 07:18
Last Post: Station_Roko
  station 3021 in https://www.lightningmaps.org jeanse 1 4,082 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 5,156 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 6,492 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 2,908 2024-07-01, 07:29
Last Post: Blubbel
