The signal data is still not updating on the online panel
The signal data is still not updating on the online panel. It has been more than a week since the station was started in the new city, and even though winter has already begun, we are still receiving many signals from distant lightning strikes. But for some reason, I still don’t get any updates in the online signal and statistics panel. At the same time, the station is working and participating in the overall calculations.
I tried turning the station off for a while, but that didn’t help. I also tried deleting the station and registering it again, but that was also without result.
user id = 2463
station id = 2891
Thank you.
After taking a quick look at station 2463, at
https://map.blitzortung.org/statistic_0....ation=2891
.. I would suggest that there is some kind of network connectivity problem. It looks like you've fixed your GPS problem from earlier this week.
If I were in your place, I would go to Settings tab on your local Blitzortung controller page, turn on Debug Network under the Debug heading, and then look at the debug logs under the Tools tab, to see if I could discover any problems there.
D
(2025-09-27, 18:20)GeezerD Wrote: After taking a quick look at station 2463, at
I tried turning the station off for some time, which caused the signal to be missing for several days.
Also, I would like to note that on the Blitzortung online map I can see the yellow tracers from my station to the lightning strikes, as well as the timely update of the 'Last Signal:' status. This shows that the signals do reach the server, but for some reason they are not updating on the online panel
PS: There are no errors in the debug logs related to the internet connection, so that should be fine
(2025-09-27, 17:42)Svarshdrgdgchik911 Wrote: The signal data is still not updating on the online panel.
station id = 2891
Thank you.
What is the exact URL of the online panel that is not updating?
This URL shows your station working fine:
D
station id = 2891
Thank you.
The panel showing the signal, its amplitude, frequency, and other characteristics has been stuck at 2025-09-21 on all URLs.
Thank you
station id = 2891
Thank you.
Thank you
Copy and paste it from your browser and post it here.
If there are more than one that are not working, it's okay to post them all here.
D
  System Blue Basic - Indicator Panel for Enclosure? DrFX 17 38,060 2025-09-19, 01:35
Last Post: davidmc36
Users browsing this thread:
