What's next for www.lightningmaps.org?
As in the topic what's next for www.lightningmaps.org? Is it possible to restore this service to full functionality and update the data, and if that's impossible then it should be disabled because I don't think it provides real station locations. By the way, I've always really liked this map and the way the data is presented on this service. Maybe I could rebuild this database after contacting the developer.
Jarek R,
Station: 2527
Please don't disable the map!
(2025-05-10, 23:10)mwaters Wrote: Please don't disable the map!
I think many of us do not want to shut down www.lightningmaps.org however the data presented by this service should be as up to date as possible to be credible. From what I see many stations are presented in the wrong locations and do not display current statistics. Maybe it would be possible to contact the developer and negotiate an update with him even if it requires a donation or taking over some of his duties.
Jarek R,
Station: 2527
Hello everyone,
I'm not responsible for lightningmaps.org, but I'd still like to know which stations aren't displayed at the correct positions?
Can you give me one or two examples?
Stations: 3071, 3073, 3074
Hi Egon,
Thank you for your interest.
Even my station 2527. I moved it to a new location 10km away, the coordinates provided by https://www.blitzortung.org/ are absolutely correct, but the actual location on https://www.lightningmaps.org/ is not even close (including the name). At the same time, the statistics for my station are not generated correctly on lightningmaps.org.
From what I have noticed, there are also missing statistics for many stations (probably for the same reason), but it is not known whether these missing statistics are not caused by long-term inactivity. I think that first it would be necessary to query the database for a list of active stations and then add their coordinates from www.blitzortung.org for correct display.
Jarek R,
Station: 2527
Great idea! Contacting the developer could help revive the project.
(2025-05-28, 07:48)AshleyClark Wrote: Great idea! Contacting the developer could help revive the project.
I agree; I really miss this map too ...!
My second station, 3138 (System Blue Basic) is on the right place next to my System Blue Classic 2641, but all there is no active data info for 3138; everything is set to 'zero' on www.lightningmaps.org.
I can only see active data for my 2641 station.
Stations: 2641 & 3138
  May we have an update RE: Blitzortung.org & Lightningmaps.org SchwabTh 3 14,221 2022-05-20, 14:40
Last Post: Egon
  error message on lightningmaps.org ho4440ew 8 42,997 2019-03-19, 08:02
Last Post: ho4440ew
  Downtimes of lightningmaps.org OliverGF 2 19,959 2017-05-31, 06:10
Last Post: DelandeC
  lightningmaps.org problem?? orion_jb2001 8 60,177 2015-02-21, 09:33
Last Post: orion_jb2001
