About the lightning location accuracy of blitzortung.org
If I purchase the BLUE SYSTEM and join blitzortung.org, what would be the lightning detection accuracy within a 10 km radius from the location where the device is installed? I imagine that the more detectors there are near the desired measurement location, the higher the accuracy will be.
Quote:Your station best contributes to the computations if it is placed in a distance between 50 km and 300 km from the discharge. If the storm is nearby, your station usually overrides. Even a very low pre-discharge will cause a very high signal strength because of its low distance.
https://www.blitzortung.org/de/Compendiu...B_14.1.pdf
https://forum.blitzortung.org/showthread.php?tid=3880
I've been using the BLUE SYSTEM for a while now, and I can say that in areas with a dense network of detectors, the accuracy is excellent.
(2024-06-25, 01:33)eddistinct Wrote: I've been using the BLUE SYSTEM for a while now, and I can say that in areas with a dense network of detectors, the accuracy is excellent.
if you give us your station number, we will upgrade your status on this forum.
Some android maps use blitzortung data to display lighting positions even at high map zoom levels. I saw which building had been struck by lightning. How accurate is lighting locating in reality?
(2024-07-10, 07:45)rafterhimself Wrote: Some android maps use blitzortung data to display lighting positions even at high map zoom levels. I saw which building had been struck by lightning. How accurate is lighting locating in reality?
Lightning
Hello Dear,
Have you some news about the System Blue Mini (functionnal, not testing, PCB 22.2 + PCB 23.1) ?
Many thanks, 73 F4HTB
  Lightning Location Logic Question DrFX 1 482 2025-03-11, 13:25
  How Does Blitzortung Handle Accuracy and Latency During Severe Storms? gyrostatics 0 503 2025-02-11, 08:39
Last Post: gyrostatics
  Lightning location? henry 2 3,456 2024-06-11, 15:51
Last Post: henry
  Question about Blitzortung lightning detector integration melissasmith 0 1,705 2024-05-08, 08:03
Last Post: melissasmith
  May we have an update RE: Blitzortung.org & Lightningmaps.org SchwabTh 3 11,671 2022-05-20, 14:40
Last Post: Egon
