System Blue rebooting often
My system blue is rebooting often, I know it see a lot of interference during the day due to solar systems around it, and initially thought that was the reason, however I have notice that it is rebooting during the night also. I have tried to use the system log to try and find a possible reason but I seem to be bombarded with remote-config errors (See the extract from the log below) and wondering if this is taking up too much processor time and tripping the watchdog?
Station 2353
Bevan
2021-11-15 00:19:45 1034.5 | AMP2: Set gain 3 on channel 0, op-amp 0
2021-11-15 00:19:45 1034.6 | HTTP-Request: realloc RecvData 0x0 (745)
2021-11-15 00:19:45 1034.6 | HTTP-Request: realloc RecvData 0x20013190 (975)
2021-11-15 00:19:45 1034.6 | REMOTE-CONFIG: Done with 1 updates and 6 errors
2021-11-15 00:19:45 1034.6 | REMOTE-CONFIG: Too much errors!
2021-11-15 00:19:45 1034.6 | HTTP-Request: free state 0x20013ac8, 0x0, 0x0, 0x0
2021-11-15 00:19:46 1035.4 | REMOTE-CONFIG: Server switched to 1
2021-11-15 00:19:48 1037.5 | HTTP-Request: Malloc state 0x20013b88, 0x20013e20 (2121), 0x20013ba8 (21), 0x20013bc8 (44) | pcb 0x20010144
2021-11-15 00:19:49 1038.6 | HTTP-Request: realloc RecvData 0x0 (745)
2021-11-15 00:19:49 1038.6 | HTTP-Request: realloc RecvData 0x20013190 (825)
2021-11-15 00:19:49 1038.6 | REMOTE-CONFIG: Done with 1 updates and 6 errors
2021-11-15 00:19:49 1038.6 | REMOTE-CONFIG: Too much errors!
2021-11-15 00:19:49 1038.6 | HTTP-Request: free state 0x20013b88, 0x0, 0x0, 0x0
2021-11-15 00:19:50 1039.4 | REMOTE-CONFIG: Server switched to 0
(2021-11-15, 00:30)VK5BD Wrote: My system blue is rebooting often, I know it see a lot of interference during the day due to solar systems around it, and initially thought that was the reason, however I have notice that it is rebooting during the night also. I have tried to use the system log to try and find a possible reason but I seem to be bombarded with remote-config errors (See the extract from the log below) and wondering if this is taking up too much processor time and tripping the watchdog?
Station 2353
Bevan
Bevan, How much lightning is there currently in your area? At the moment the US is in a lightning dry condition and my system also reboots at least once a day due to that. This is normal
I am also having frequent reboots, I would say every 2 or 3 hours. I have similar messages about errors in my log, and when I checked the Remote Configuration section of the Status page, I see:
Requests 87 with 232kB and 88 errors.
This was after running for about 7 minutes.
Messages from the debug log are:
2021-11-16 16:40:36 563.1 | HTTP-Request: Malloc state 0x20013c68, 0x20013e58 (2160), 0x20013c88 (23), 0x20013ca8 (44) | pcb 0x20010478
2021-11-16 16:40:37 564.4 | HTTP-Request: realloc RecvData 0x0 (745)
2021-11-16 16:40:37 564.4 | HTTP-Request: realloc RecvData 0x200131c8 (965)
2021-11-16 16:40:37 564.4 | REMOTE-CONFIG: Set max relative gain: rgain_max=6400, threshold_min=100 on amp0, ch2
2021-11-16 16:40:37 564.4 | REMOTE-CONFIG: Done with 2 updates and 2 errors
2021-11-16 16:40:37 564.4 | REMOTE-CONFIG: Too much errors!
2021-11-16 16:40:37 564.4 | HTTP-Request: free state 0x20013c68, 0x0, 0x0, 0x0
2021-11-16 16:40:38 565.0 | REMOTE-CONFIG: Server switched to 1
2021-11-16 16:40:41 568.1 | HTTP-Request: Malloc state 0x20013c68, 0x20013e58 (2184), 0x20013c88 (21), 0x20013ca8 (44) | pcb 0x20010330
2021-11-16 16:40:41 568.5 | HTTP-Request: realloc RecvData 0x0 (680)
2021-11-16 16:40:41 568.5 | REMOTE-CONFIG: Done with 1 updates and 2 errors
2021-11-16 16:40:41 568.5 | REMOTE-CONFIG: Too much errors!
2021-11-16 16:40:41 568.5 | HTTP-Request: free state 0x20013c68, 0x0, 0x0, 0x0
2021-11-16 16:40:42 569.0 | REMOTE-CONFIG: Server switched to 0
2021-11-16 16:40:44 571.1 | AMP1: Set gain 1 on channel 1, op-amp 1
2021-11-16 16:40:45 572.0 | Tracker: Interference mode 1 end.
I just found a thread called "server / database issues", which sounds like the same issue.
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 51,593 2025-04-19, 23:25
Last Post: DrFX
  Whats the best advice on regular rebooting of RED? Dale.Reid 4 38,179 2016-05-31, 01:06
Last Post: Dale.Reid
