Strikes shown on fixed size map not shown on dynamic size map
We have a significant storm overhead in the Shetland islands at the moment.  there are many strikes shown on the fixed size  map which correlates with our local experience.  However there is hardly anything showing on the dynamic size map ! I think there is a problem !
Tony Erwood
Lunna, Shetland.
08:11 GMT
(2020-08-21, 08:13)tony.erwood Wrote: We have a significant storm overhead in the Shetland islands at the moment.  there are many strikes shown on the fixed size  map which correlates with our local experience.  However there is hardly anything showing on the dynamic size map ! I think there is a problem !
Tony Erwood
Lunna, Shetland.
08:11 GMT
Hello Tony,
Do you mean the dynamic lightningmaps.org?  My guess is that you need to select both LMO ant BTO in the drop down menu on top to the left.
Also, try the newer enhanced BTO dynamic map at https://map.blitzortung.org/?y#3.71/57.39/0.36
Adjust the settings in the drop-down menu to suit.
Hover your mouse where mine is in the snapshot, then select both.
Tony Erwood
Lunna, Shetland.
08:11 GMT
Hello Tony,
I mean
https://www.blitzortung.org/en/live_dynamic_maps3.php
I don't see any other drop down menu except the one that leads to this link.
(2020-08-21, 17:14)dupreezd Wrote: Hover your mouse where mine is in the snapshot, then select both.
I don't know where you got that page from.  I don't see it when viewing www.blitzortung.org , I only see a drop down menu for "Real Time Maps"  (and also "Historical Data" and "Further Info" and "Project Area").
https://www.lightningmaps.org/
(2020-08-21, 21:19)mwaters Wrote: https://www.lightningmaps.org/
Thank for that Mike, I've not seen that website before.
What is the relationship between lightningmaps.org and blitzortung.org ?
I'm reporting a problem with the blitzortung.org website that needs to be fixed.
Tony.
  seeing map strikes and counting seconds for distance GeezerD 0 16,472 2025-09-06, 22:14
Last Post: GeezerD
  Local lightnong not on map, even though there are detectors GeezerD 3 24,831 2025-08-22, 19:38
Last Post: GeezerD
  New User – How Accurate Are Local Strikes on the Map? fiasco 1 15,027 2025-05-09, 06:22
  Lightning block not showing map ramiroflores 1 31,579 2024-10-15, 18:55
Last Post: mwaters
  Lightning not showing on the map deesalsphotos 0 13,511 2021-12-26, 09:27
Last Post: deesalsphotos
