2020-04-24, 22:28
I'm a participant (station 2441, user1905). I used to be subscribed as participant but now seem to be as a registered member. How do I change forum status to participant?
how to change status to participant
2020-04-24, 22:28
2020-04-24, 23:14
One of the admins will see this and help you. Probably Cutty will do it.
2020-05-13, 15:09
Same here! I'm a participant for station 2410, user 1887
I never had a participant status
2020-06-26, 16:19
I have station 2733 active, but nut participant status.
2020-06-30, 08:19
(This post was last modified: 2020-06-30, 08:22 by MTO-Mareuil.)
Hello !
I am a participant (station 2401 user 1880) and my profile on the forum only shows that I am registered as a member of the forum !!! how to change status? Thank you for your help.
2020-06-30, 11:46
2020-06-30, 16:36
(2020-06-30, 11:46)cutty Wrote:thank you so much !!!(2020-06-30, 08:19)MTO-Mareuil Wrote: Hello !you're updated... (no need to shout...
2020-07-20, 19:12
Dear all,
Greetings from Bulgaria. Just became a participant (thanks, Egon!). My first Station ID is 2757 and my User ID is 2114. Can you please change my status to "Participant". Thanks in advance! Kind Regards, Koleto
2020-07-21, 11:51
2020-07-21, 17:08
Welcome! You can change your signature by following the simple instructions at https://forum.blitzortung.org/showthread...0#pid21490.
2020-07-29, 01:24
Hello !
I am a participant (station 2764 user 2146) and my profile on the forum only shows that I am registered, how to change status to participant. Thank you for your help.
2020-08-20, 19:05
Hi!
I have de same problem Station ID 2782 User-ID: 2155 Thanks! Mauro
2020-08-20, 19:12
2020-08-20, 19:23
https://forum.blitzortung.org/showthread.php?tid=2764 ("Station Isn't Recognized. Not on List. ETC") is the correct thread for this, and the OP here should have been redirected to it.
Egon and the moderators will see it quicker if you post it there. Please read Cutty's instructions at the top first. I suggest that this thread be locked.
2020-08-20, 19:26
(2020-08-20, 19:12)Eric.Wouters Wrote:(2020-08-20, 19:05)m.sedrani Wrote: Hi!there you go
2020-08-20, 19:28
(2020-08-20, 19:23)mwaters Wrote: https://forum.blitzortung.org/showthread.php?tid=2764 ("Station Isn't Recognized. Not on List. ETC") is the correct thread for this, and the OP here should have been redirected to it. Thanks for the info. |
| Participant status | tkerby | 2 | 16,988 |
2023-01-28, 17:16 Last Post: tkerby |
| Getting Participant status. Not sure what I'm doing wrong. | michidragon | 15 | 103,278 |
2018-10-14, 03:05 Last Post: neil9 |
| Become a participant | sunwind | 4 | 38,949 |
2018-08-08, 23:21 Last Post: kevinmcc |
