	Threads: 7
I can't read those posts that are moved etc. Where did it go wrong with my subscription? Can only see the public part of the forum. I'm station 2588 and like to read the fine-tune details etc.
Jack
Jack
Station: 2588
	Threads: 55
		The problem should be solved now.
	Threads: 45
		Egon, thank you for all your hard work. I know you must be extremely busy.
	Threads: 7
		2019-08-12, 09:49
(This post was last modified: 2019-08-12, 09:50 by old_dutch.)
		 (2019-08-11, 18:55)Egon Wrote:  The problem should be solved now.
Yes it is, thank you very much. And I noticed that all other stations here in the Philippines are in the Oceanic region except me?. Any special reason for that?
Jack
Jack
Station: 2588
		 (2019-08-10, 08:59)old_dutch Wrote:  Hello,
Jack
Sadly, I am having the same problem.
I've recently assembled and registered a station (2616), but can not access parts of the forum.
Does it require special moderaror action to get upgraded to the "operator" status on the forum?
Slaviks
	Threads: 63
		 (2019-08-23, 12:56)Slaviks Wrote:  .....
Slaviks
Yes, unfortunately.... the 'bridging' between the Blitzortung databases, and the forum databases requires a complete rebuild, and that is dellayed as refinements are completed on the Blitzortung / LightningMaps / Forum platforms/servers...
...we have to do it manually, and it is a real irritation for all... there is no current 'flag' to tell us that someone needs upgrading....
...apologies,...
		 (2019-08-23, 14:08)cutty Wrote:   (2019-08-23, 12:56)Slaviks Wrote:  .....
Slaviks
...apologies,...
Thank you, Mike!
The forum works now, I feel green and privileged!
PS. I am very excited as it looks I've found an magnetically quiet spot in my house....
	Threads: 2
		I think that I'm having the same problem.  I've recently started station 2559, but still can't see some posts in this forum.  Would it be possible to ask a moderator to see if my accounts are also out of whack?
