Threads: 26
Hi for some weeks I have a problem with the red board
I see a error No Amplifier connected
I have test this with 2 antennas and also with 2 amp boards
All with 2 different ferrite antenna
1 on the roof and for this moment 1 into this room
The firmware version I have is now 8.0
But also with the 7.4 version I have the same problem
Ware can I look for fix this problem ?
Greetings Gert
Threads: 73
Does the LEDs on the amp turn on?
Threads: 26
(2016-09-04, 20:08)DelandeC Wrote: Does the LEDs on the amp turn on?
Only the Red led is on if I see the error
Green and Yellow are off
now the amp is turning on by him self ? and I see blinking the 4 Yellow led and also the Green led is now on and also the Red
its very strange but the amp is turning off and on by him self
Threads: 73
Did you try a other cable?
Threads: 26
(2016-09-05, 04:56)DelandeC Wrote: Did you try a other cable?
Yes I have
Threads: 26
Now I see into the screen from the board a new error
I see now into the SYS option Vin Too low !
don't know if this normal ?
Threads: 9
(2016-09-05, 17:55)Rothuize Wrote: Now I see into the screen from the board a new error
No this is not normal, it is telling you that your power supply is faulty or underpowered.
Try a different power supply that can supply 5 to 5.3V at a minimum of 2A.
Ben.
RED Station: 878, Flightradar24: F-EGLF1, Open Glider Network: Aldersht2, PlanePlotter:
M7.
878
Threads: 26
(2016-09-05, 18:46)Benedict.Smith Wrote: (2016-09-05, 17:55)Rothuize Wrote: Now I see into the screen from the board a new error
Ben.
Thanks Ben
Only I do not have a extra power supply for this moment
for now I have it into the USB from the computer .. and I know this will not by a good idea,, but its for this moment working 4.9V
I do have a power supply for the iphone but I think this will by also not a good idea
I will look tomorrow for a power supply
maybe this is also the problem with the Amplifier to low power and the Amplifier turns off ??
for this moment I run the board with 2 Amplifiers 2x ferrite antennas now I hope all will by work ok again
thanks for this info
greetings Gert
Threads: 77
Try the PS for your iPhone
Maybe you have meassured 4,9 with a voltmeter, but it don't tell you how noisy it is
/Richo
