#94
(2014-08-22, 16:53)W3DRM Wrote: Can you explain how the Thunder selections work (the difference in the various Thunder settings, that is)? I don't see any differences in the display when I go from one selection to another (OFF to MAX). In fact, I always see the expanding rings on each strike even in the OFF position.
There are differences in the amount of growing circles, minimum zoom level and time where the circle is visible. You can see it very good on storms with high strike rate. When there are too much strokes, you can loose overview in "max" setting. Lowering details is also useful for slow computers or (mobile-)devices. A similar feature for the stations will be added soon.
RE: Real time Lightning Map - by RichoAnd - 2014-05-09, 18:32
RE: Real time Lightning Map - by cutty - 2014-05-09, 19:59
RE: Real time Lightning Map - by scilover - 2020-06-03, 10:54
RE: Real time Lightning Map - by Dale.Reid - 2014-05-09, 20:55
RE: Real time Lightning Map - by Tobi - 2014-05-09, 21:12
RE: Real-time Lightning Map - by cutty - 2014-05-09, 22:16
RE: Real-time Lightning Map - by John.Sacrey - 2014-05-09, 23:56
RE: Real-time Lightning Map - by Tobi - 2014-05-10, 16:21
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-11, 00:46
RE: Real-time Lightning Map - by cutty - 2014-05-11, 01:21
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-11, 03:22
RE: Real-time Lightning Map - by robo - 2014-05-11, 12:11
RE: Real-time Lightning Map - by aib - 2014-05-11, 12:24
RE: Real-time Lightning Map - by cutty - 2018-12-16, 17:05
RE: Real-time Lightning Map - by Tobi - 2014-05-11, 17:32
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-11, 18:54
RE: Real-time Lightning Map - by Tobi - 2014-05-11, 19:47
RE: Real-time Lightning Map - by weatherc - 2014-05-12, 09:36
RE: Real-time Lightning Map - by Tobi - 2014-05-15, 20:50
RE: Real-time Lightning Map - by weatherc - 2014-05-15, 21:21
RE: Real-time Lightning Map - by Tobi - 2014-05-16, 17:54
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-17, 00:15
RE: Real-time Lightning Map - by saschaa - 2014-05-18, 18:42
RE: Real-time Lightning Map - by DelandeC - 2014-05-20, 17:22
RE: Real-time Lightning Map - by Tobi - 2014-05-20, 21:18
RE: Real-time Lightning Map - by DelandeC - 2014-05-21, 09:07
RE: Real-time Lightning Map - by steelek - 2014-05-24, 15:48
RE: Real-time Lightning Map - by cutty - 2014-05-24, 15:50
RE: Real-time Lightning Map - by HamelGre - 2014-05-30, 12:36
RE: Real-time Lightning Map - by Tobi - 2014-05-30, 17:22
RE: Real-time Lightning Map - by HamelGre - 2014-05-30, 19:58
RE: Real-time Lightning Map - by cutty - 2014-05-30, 21:34
RE: Real-time Lightning Map - by Tobi - 2014-05-31, 06:37
RE: Real-time Lightning Map - by HamelGre - 2014-05-31, 11:19
RE: Real-time Lightning Map - by zalama - 2014-06-07, 13:04
RE: Real-time Lightning Map - by mabro - 2014-06-07, 13:39
RE: Real-time Lightning Map - by Knickohr - 2014-06-07, 14:09
RE: Real-time Lightning Map - by Tobi - 2014-06-07, 14:51
RE: Real-time Lightning Map - by zalama - 2014-06-08, 05:29
Real-time Lightning Map - by NosDE - 2014-06-09, 20:08
RE: Real-time Lightning Map - by Tobi - 2014-06-10, 10:14
RE: Real-time Lightning Map - by weatherc - 2014-06-10, 12:29
Real-time Lightning Map - by NosDE - 2014-06-10, 10:39
Real-time Lightning Map - by NosDE - 2014-06-10, 12:40
RE: Real-time Lightning Map - by Tobi - 2014-06-10, 18:17
RE: Real-time Lightning Map - by weatherc - 2014-06-11, 14:22
RE: Real-time Lightning Map - by Tobi - 2014-06-11, 18:19
Real-time Lightning Map - by NosDE - 2014-06-11, 19:29
RE: Real-time Lightning Map - by Tobi - 2014-06-11, 19:51
Real-time Lightning Map - by NosDE - 2014-06-11, 21:45
RE: Real-time Lightning Map - by W3DRM - 2014-06-14, 21:29
RE: Real-time Lightning Map - by cutty - 2014-06-14, 21:39
RE: Real-time Lightning Map - by W3DRM - 2014-06-14, 21:45
RE: Real-time Lightning Map - by Tobi - 2014-06-14, 21:53
RE: Real-time Lightning Map - by W3DRM - 2014-06-14, 21:59
Real-time Lightning Map - by NosDE - 2014-06-14, 22:02
RE: Real-time Lightning Map - by Tobi - 2014-06-20, 15:44
RE: Real-time Lightning Map - by AleT - 2014-07-25, 13:27
RE: Real-time Lightning Map - by HamelGre - 2014-06-21, 13:10
RE: Real-time Lightning Map - by Tobi - 2014-06-21, 13:45
RE: Real-time Lightning Map - by ecreif - 2014-06-23, 14:56
RE: Real-time Lightning Map - by wxrman - 2014-06-26, 00:50
RE: Real-time Lightning Map - by jade - 2014-06-26, 04:21
RE: Real-time Lightning Map - by jumpjack - 2014-06-26, 12:25
RE: Real-time Lightning Map - by Tobi - 2014-06-26, 17:57
RE: Real-time Lightning Map - by cutty - 2014-06-26, 18:17
RE: Real-time Lightning Map - by weatherc - 2014-07-13, 13:43
RE: Real-time Lightning Map - by Tobi - 2014-07-13, 15:25
RE: Real-time Lightning Map - by Knickohr - 2014-07-13, 15:50
RE: Real-time Lightning Map - by Tobi - 2014-07-13, 17:47
RE: Real-time Lightning Map - by Knickohr - 2014-07-13, 17:53
RE: Real-time Lightning Map - by HolzHaus - 2014-07-14, 23:29
RE: Real-time Lightning Map - by Tobi - 2014-07-16, 10:47
RE: Real-time Lightning Map - by HolzHaus - 2014-07-16, 11:24
RE: Real-time Lightning Map - by cutty - 2014-07-14, 23:31
RE: Real-time Lightning Map - by Tobi - 2014-07-16, 18:22
RE: Real-time Lightning Map - by ari.jasberg - 2014-07-19, 14:54
R: RE: Real-time Lightning Map - by jumpjack - 2014-07-20, 08:20
RE: LightningMaps.org: Real-time Lightning Map - by Tobi - 2014-08-23, 08:41
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 13,931 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 18,781 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 25,526 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 23,501 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 16,315 2024-07-01, 07:29
Last Post: Blubbel
