(2014-08-16, 14:52)Tobi Wrote: Tell me the firmware version, what you see on the LCD and which of the four user LEDs are on when the problem occurs. Some more lines before the log might help too.
Hello Tobi,
thanks for fast reply?
On The LCD are the same informations as in the LOG.
Tree LED´s are on : red, yelow, green
Blue is off.
Here the LOG.
Can i call you?
2000-01-01 00:00:00 0 | ================ Blitzortung STM32F4 Controller Board ================
2000-01-01 00:00:00 0 | Firmware Rev. 7.3b1 / Aug 9 2014 19:28:42 (Git 7.3b1-0-g8aa7462)
2000-01-01 00:00:00 0 | Hardware Rev. 10.4 (Id 2)
2000-01-01 00:00:00 0 | Reset condition: BOR=1 PIN=1 POR=1 SOFT=0 IWD=0 WWD=0 LPW=0
2000-01-01 00:00:00 0 | HCLK: 168MHz
2000-01-01 00:00:00 0 | PCLK1 (APB1): 42MHz
2000-01-01 00:00:00 0 | PCLK2 (APB2): 84MHz
2000-01-01 00:00:00 0 | SYSCLK: 168MHz
2000-01-01 00:00:00 0 | ======================================================================
2000-01-01 00:00:00 0 | === ADC Defaults ===
2000-01-01 00:00:00 0 | Resolution: 12bits
2000-01-01 00:00:00 0 | Divider: 2
2000-01-01 00:00:00 0 | Sample Cycles 1: 56
2000-01-01 00:00:00 0 | Sample Cycles 2: 28
2000-01-01 00:00:00 0 | === ADC Configuration ===
2013-01-01 00:00:00 0 | START: Loaded TOA-Lightning-ALERT settings.
2013-01-01 00:00:00 0 | START: Loaded ACTION settings.
2013-01-01 00:00:00 0 | START: Initialized WEBSERVER on port 80.
2013-01-01 00:00:00 0 | === Init HTTP Remote CONFIG ===
2013-01-01 00:00:00 0 | REMOTE-CONFIG: Static URL1 'http://tracker.blitzortung.org/control/station.php'
2013-01-01 00:00:00 0 | REMOTE-CONFIG: Static URL2 'http://www.lightningmaps.org/control/station.php'
2013-01-01 00:00:00 0 | REMOTE-CONFIG: Checking every 300s
2013-01-01 00:00:00 0 | === Tracker (TM by Egon) ===
2013-01-01 00:00:00 0 | TRACKER: Init Settings...
2013-01-01 00:00:00 0 | Tracker: Using buffer of 0bytes (0x10000000 - 0xFFFFFFF) for 35 signals
2013-01-01 00:00:00 0 | Tracker: Using buffer 35 for noise level calculation
2013-01-01 00:00:00 0 | TRACKER: Call Amplifier Setup...
2013-01-01 00:00:00 0 | ===========================================================================
2013-01-01 00:00:00 0 | [Hard fault handler - all numbers in hex]
2013-01-01 00:00:00 0 | R0 = 80000000
2013-01-01 00:00:00 0 | R1 = 80e8
2013-01-01 00:00:00 0 | R2 = 3fd8
2013-01-01 00:00:00 0 | R3 = 3fd7
2013-01-01 00:00:00 0 | R12 = 0
2013-01-01 00:00:00 0 | LR [R14] = ffffffe9 subroutine call return address
2013-01-01 00:00:00 0 | PC [R15] = ff68df90 program counter
2013-01-01 00:00:00 0 | PSR = 2000003d
2013-01-01 00:00:00 0 | BFAR = e000ed38
2013-01-01 00:00:00 0 | CFSR = 1
2013-01-01 00:00:00 0 | HFSR = 40000000
2013-01-01 00:00:00 0 | DFSR = 0
2013-01-01 00:00:00 0 | AFSR = 0
2013-01-01 00:00:00 0 | SCB_SHCSR = 0
Stations: 1146
