Can no longer log into System Blue Controller, Web Brouser Interface
Pete,
I'd suggest a thorough reading of
https://docs.lightningmaps.org/station-o...e/#network ... what stuff does.
https://docs.lightningmaps.org/station-o..._recovery/  attempts to fix.
One possible very simple 'glitch'.... Your browser may assume you want an SSL connection, which will be refused. Make sure you're attempting to connect at HTTP://192.1.x.xxx"  NOT https://  My browser started that 'thinking for the operator' crap with a recent update...
OTHERWISE:
It appears that your only recourse is a factory reset. Especially if you've inadvertently disabled the webserver.
For this you'll need physical access to the controller so you can push some buttons.
once accomplished,
The factory default address will be 192.168.1.235, and all settings will return to factory fresh.
If you still can't find it after all the options, including security, passwords, etc are 'factory', you may have to look outside the Blitzortung system for the issue.
Those links above give suggestions, info, and procedures for possible scenarios re: can't connect, etc, (including using the rarely mentioned enter "http://blitzortung" in the browser, which might not work in all network setups . May not work if have more than one BT  system active on your network...)
RE: Can no longer log into System Blue Controller, Web Brouser Interface - by cutty - 2025-05-19, 11:48
! - by cutty - 2025-05-19, 17:06
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 52,249 2025-04-19, 23:25
  Question about web interface williammurdock 3 13,721 2024-08-10, 08:33
Last Post: DelandeC
  Can't Log In k2ors 2 14,831 2024-07-18, 19:32
  cannot log in opadavis2 5 43,667 2019-09-16, 13:19
  System blue web page fails EA3BNF 5 45,164 2017-06-03, 06:55
Last Post: EA3BNF
