2024-12-31, 12:45
(2024-12-30, 18:24)cutty Wrote: ...
(2024-12-30, 14:03)PetrosKa Wrote: Thank Mike,
After reading your post and looking again on the signals I saw only the red channel registering, so something is wrong with the antenna, today the weather improved so I got up on the roof.
Sure enough there was not power to the preamp, I was pretty sure that the cable was ok since it was good quality cable, any way I put a new cable again and every thing looks good. Thanks everyone for your responses.
Petros
Arrgh,... You have lots of junk signals! Several varieties.
Thoughts:
Is that net cable to preamp SHIELDED?
Make sure using UNSHELDED from controller to router!
Is preamp or controller connected to any ground? Suggest no ground.
How's your 5v main power supply?
Any solar power devices , electric fences, power converters, nearby?
...may need to do 'walkaround' with off-station AM radio and, hopefully, track down noise...
May have to tell Hermes he's grounded till he resolves St. Elmo's Fire issue with Winged Sandals and Salty Humid Aegean Air... ?
Yes I know about the noise I get during the day, it comes from the inverter of the solar panels. When weather permits it I try to relocate the antenna.
The cable to the preamp is FTP CAT6 PET, no ground connected to any antenna system and the patch cord from controller to router is UTP. The power supply is this, I don't know if it's good enough.
Thanks Mike.
