New system - not certain if it work
(2024-04-25, 19:33)cutty Wrote:
(2024-04-25, 17:14)Bobby_Two_Dogs Wrote: Thanks for the information - I've updated my antennas, hopefully they are correct as I didn't build the system.
Didn't mean to offend anyone - I'm just wasn't certain if things were working correctly.  I noticed the same issue with map.blitzortung.org - my device never seems to get a hit - so was wondering if something on my end was wrong.
Thanks for letting me know it's working.
Robert
OOPs... Sorry Robert... if my reply seemed a bit 'terse' or otherwise,...... I apologize, I guess I can come across as 'snarky' sometimes... without meaning to... was in a hurry and running behind this morning...
Yeah, Tobi hopes to revitalize that site processing at some point, simply hasn't got time...
I assume you have ferrites on the H fields, and possibly using the supplied 'mini' probe for E field...
I don't know what the core dimensions are that came with your kit,  would  10 x 120mm, perhaps, sound correct? ...depends on the source, and your 3024, like my 3020 test system, is an 'outside source' Blue 19.5 clone.
The reason that antenna info is important: every 'antenna family' has certain delay and response ballpark parameters,
and the system takes that 'generic' blueprint into account when analyzing signal parameters...  It already knows what
responses are programmed into a systems controller, depending on gain, trigger, standard filtering, ... so the only
response variable is the antenna itself... most crucial for the H fields obviously.  An 'incorrect' or missing antenna parameter
could determine whether certain signals even become 'valid', much less progress to 'locating'...
Mike,
I contacted the gentleman I purchsed the system from and he let me know the information.  I have filled in the fields.  Seems the system has two Ferrite 200's and one e-field 100 - i've put that information into the station record.
NP on the other item, I get it.  Sometimes I'm just a little too forward and want to make ceratin I'm not ruffeling feathers.
Looking forward to seeing my site being used on the maps - when Tobi has time of course...!!!
Cheers,
Robert
Stations: 3024
  Blitzortung doesn’t work colebonelli 1 13,464 2024-10-15, 15:00
Last Post: Kets_One
  ELI5: How do lightning tracker websites work? Johnlarry 2 28,140 2020-06-09, 10:10
Last Post: scilover
  Some questions for begin of station work hashemiyan 1 21,795 2016-05-16, 13:59
Last Post: DelandeC
