Vector map - choosing map style
Map style that one can choose from four modes (using the popup in the upper right corner).
My experience shows that it quite often goes back to default, also it is somewhat cumbercome to switch it back to desired mode. Couple times I selected the mode and ticked the save in cookies checkbox and after refresh it all went to defaults. BTW: is the order of doing this significant? - choosing mode and THEN ticking save or the other way round.
I don't change any of the other settings, so it might be problem with this particular setting or with everything that is stored in the cookie.
Once the changed setting is finally correctly saved, it is working for some time.
Vector map - choosing map style - by Sparkee - 2021-09-22, 08:43
RE: Vector map - choosing map style - by Egon - 2021-09-27, 16:20
RE: Vector map - choosing map style - by Sparkee - 2021-09-28, 09:28
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 14,067 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  embedding blitzortung-map in grafana dashboard gono 1 23,117 2025-04-29, 02:43
  Map on Grafana f1ssf 1 16,657 2025-04-29, 02:42
  Map active Stations Blitzortung Europe patoffgrid 2 23,345 2024-06-22, 17:02
Last Post: patoffgrid
  Map no longer displays? W2PJ-WX 2 22,745 2022-11-13, 22:49
Last Post: W2PJ-WX
