(2021-08-31, 16:19)Szutek Wrote: Hello,Default "sort" is by "counter_used" (USED) column, "descending" ... which will always show stations / region with the highest 'used' count.
Statistics page for a couple of weeks now
(https://www.blitzortung.org/en/station_list.php)
displays stored highest hourly results instead of last hour's results.
Is this an intended change?
Peter
On some chosen page selections, or specific sort request, an "orphan" database from August 19th has a higher USED count then the current 'real-time' database, so the table, erroneously, lists those 'orphan' numbers ahead of others. They can be distinguised by the "last signal" date of "August 19", and usually a server name of "whateverRegionName 2" instead of ""whateverRegionName 1"
Issue is a tough one, but Egon's continuing to look at it, as far as I know,.
Additional info, and a hint, at this post, on the Operator's Internal forum:
https://forum.blitzortung.org/showthread...3#pid24203
