Blue e-field antenna question
Thank you for your reply.
Mine (17.2) is definitely not connected. I did check with a DVM, but more importantly, using a bright light I can see clearly that there is no copper spanning the bridge between the two sections.
Regarding placement, I believe I read that the e-field antenna can be placed above a metal roof and the h-field can be placed under a metal roof. Is that true and if so, is there a minimum distance that they should be away from the roof?
The roof in question covers a concrete pad and is away from the house and any electrical wires, devices or machinery. It is about 12' (~3.7m) above the ground. I could place either in a nearby tree about 20' up (~6m) if that would be meaningfully better.
Blue e-field antenna question - by llowrey - 2021-07-05, 18:40
RE: Blue e-field antenna question - by llowrey - 2021-07-06, 14:34
  Making a copper tubing H-field antenna Geewizard 3 20,407 2025-06-02, 18:02
  My E-field antenna setup TomVal 3 27,602 2020-11-05, 15:48
  blue ferrite / loop antenna connection? MTO-Mareuil 1 19,308 2020-10-20, 11:43
  GPS antenna SYSTEM BLUE ! IK1TTD 9 76,099 2020-06-03, 12:16
Last Post: GJ7DNI
  Can E-field antenna be casted in resin? OH4GRM 3 27,080 2020-06-01, 13:19
Last Post: dupreezd
