(2018-02-10, 01:13)higherperspective Wrote:
(2018-02-09, 09:32)PeterTim Wrote:
(2018-02-08, 22:21)higherperspective Wrote:
(2018-02-08, 14:47)PeterTim Wrote: Oke one question is the housing for system blue pcb 19.4?
I understood that there are some minor difference between the systemboards.
So I wonder if all the holes are on the right place.
If so I am interested.
Peter
That's correct, they're designed for the current 19.4 units.
However, if you're able to give me some measurements of mounting hole locations and some images of the other boards, I can certainly modify the design to suit.
I will see if I can get some info about the measurements.  Is it possible to make a housing with clear acrylic? so not the wite and blue but complete clear?
I will make a picture of the housing Egon created (or someone else - but I mean the housing blitzortung delivers when you order it.
I can make them in any colour your like, including clear.
Well I can't find the measurements - maybe Egon or Tobi can point us in the right direction. I will give that a try - send a email and wait what happens -  Keep you posted.
This is the reply I 've got from Egon.
the board size is the same for all version 19.x, see
Thee are the dimensions of the board. So separated:
The controller board is 138.43 x 130.18 (as far as I can see)
Hope this is use full for you.
http://de.blitzortung.org/Compendium/Har..._5_brd.png
Stations: 2083
RE: Housing for System Blue (laser cut/3d print) - by PeterTim - 2018-02-14, 09:08
  Lightning in 3D. mvdswaluw 1 22,260 2020-06-09, 10:10
Last Post: scilover
