Help new system blue
#39
Hi Mike, For five minutes work, you can take them all out, test the board and check the LEDs and have them back in place if they are O.K.
You will then know if that is the case or not.
There is no point in just jumping from one point to another.
At the moment they are not working, so that is a good place to start!
You can not test them on the board, because they are in parallel with the ones already on the board, if one is the wrong way around then neither of them will light.
This is not some sort of personality thing, although at times I am not very diplomatic, this is just double checking.
You did not answer the question about test equipment or whether there is anyone local to you who can maybe help.
Bear with us, we are only trying to help, if you are not going to listen, and try some of these things, then quickly you are going to find yourself doing it alone.
Then what do you do?
If you ask? Then you have to have some faith that someone can help, if you don't follow the clues given, you are not going to do anything to resolve this problem.
Kindest regards,
Brian.
Help new system blue - by mikey141 - 2017-09-17, 13:37
RE: Help new system blue - by pasense - 2017-09-17, 14:04
RE: Help new system blue - by mikey141 - 2017-09-17, 14:12
RE: Help new system blue - by pasense - 2017-09-17, 14:20
RE: Help new system blue - by mwaters - 2017-09-17, 14:22
RE: Help new system blue - by mwaters - 2017-09-17, 14:33
RE: Help new system blue - by mikey141 - 2017-09-17, 14:52
RE: Help new system blue - by mwaters - 2017-09-17, 14:56
RE: Help new system blue - by mikey141 - 2017-09-17, 14:59
RE: Help new system blue - by mikey141 - 2017-09-17, 15:22
RE: Help new system blue - by pasense - 2017-09-17, 15:44
RE: Help new system blue - by mikey141 - 2017-09-17, 16:41
RE: Help new system blue - by pasense - 2017-09-17, 16:47
RE: Help new system blue - by mikey141 - 2017-09-17, 18:23
RE: Help new system blue - by pasense - 2017-09-17, 18:31
RE: Help new system blue - by mwaters - 2017-09-17, 18:31
RE: Help new system blue - by mikey141 - 2017-09-17, 18:43
RE: Help new system blue - by pasense - 2017-09-17, 19:02
RE: Help new system blue - by mikey141 - 2017-09-17, 19:08
RE: Help new system blue - by pasense - 2017-09-17, 19:10
RE: Help new system blue - by mwaters - 2017-09-17, 21:21
RE: Help new system blue - by allsorts - 2017-09-17, 19:53
RE: Help new system blue - by mikey141 - 2017-09-17, 20:00
RE: Help new system blue - by mwaters - 2017-09-17, 21:23
RE: Help new system blue - by mikey141 - 2017-09-17, 20:05
RE: Help new system blue - by readbueno - 2017-09-18, 00:18
RE: Help new system blue - by mwaters - 2017-09-18, 01:27
RE: Help new system blue - by kevinmcc - 2017-09-18, 01:27
RE: Help new system blue - by allsorts - 2017-09-22, 22:51
RE: Help new system blue - by cutty - 2017-09-18, 14:13
RE: Help new system blue - by mikey141 - 2017-09-18, 16:33
RE: Help new system blue - by mwaters - 2017-09-18, 16:39
RE: Help new system blue - by mikey141 - 2017-10-01, 17:25
RE: Help new system blue - by mwaters - 2017-10-01, 17:55
RE: Help new system blue - by readbueno - 2017-10-01, 18:29
RE: Help new system blue - by mwaters - 2017-10-01, 18:33
RE: Help new system blue - by readbueno - 2017-10-01, 18:45
RE: Help new system blue - by mikey141 - 2017-10-01, 19:06
RE: Help new system blue - by readbueno - 2017-10-01, 19:43
RE: Help new system blue - by mikey141 - 2017-10-01, 19:51
RE: Help new system blue - by readbueno - 2017-10-01, 20:13
RE: Help new system blue - by cernese - 2018-02-06, 23:24
RE: Help new system blue - by readbueno - 2018-02-07, 00:41
Users browsing this thread: 9 Guest(s)
