2017-09-17, 14:12
(2017-09-17, 14:04)pasense Wrote: Please tell us precisely what you connected. Did you connect the system to a router? Did you add a small makeshift E field antenna just to check? Or did you connect the H field ferrites?
When connecting to a router, you can check via the router which IP address the system has, make it fixed, then you can access the system interface via the browser.
I just connected the system to the router using a crossover RJ45 cable and nothing else to see if the system works contently. The system wasnt looking at the router so not giving me any IP address
