Blue H field Ferrite antenna in L or Delta shape?
(2017-03-30, 00:57)allsorts Wrote: I started with all three loops together but local conditions mean that 90 degrees between the loops produces useless signals. See post #5 ... I now have seperate vertical loops with a horizontal around one of them.
Starting separate means you don't have to rebuild if you need to use the null of a loop to reduce local interfernce. If you have the loops fixed at 90 degrees, you can null the interference on one but the other is then aligned for maximum pick up...
That makes sense. It's probably easier to build them separately
Michael Lloyd  NE5U
Weimar, TX USA
Stations: 1745
RE: Blue H field Ferrite antenna in L or Delta shape? - by Mike6158 - 2017-03-30, 03:06
  Making a copper tubing H-field antenna Geewizard 3 20,410 2025-06-02, 18:02
  Blue e-field antenna question llowrey 2 22,164 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 27,605 2020-11-05, 15:48
  blue ferrite / loop antenna connection? MTO-Mareuil 1 19,309 2020-10-20, 11:43
  GPS antenna SYSTEM BLUE ! IK1TTD 9 76,102 2020-06-03, 12:16
Last Post: GJ7DNI
