Supplied Ferrites all have small knot in one wire
(2016-11-02, 10:42)elythomaslumber Wrote:
(2016-11-02, 10:15)nellyt Wrote: The pre-wound ferrites that came with my Blue kit all have a small loose knot tied in one of the two wires.
What is the significance of this?
Should this be connected to a certain pin of the pre-amp?
thanks
Connect those one with the knot to the + terminal.
The polarity doesn't matter for the Blitzortung system.  This is a TOA / TOGA system, and all it needs is stroke impulse data. The polarity would matter if this were a DF locator, which it is not.  It's good to keep 'consistent' however, since it is possible, if you do everything correctly, (Same polarity, Correct physical orientation) using two ferrites at 90° to 'eyeball' the direction of a signal on local signal display...e.g. attached.... which can help track down "interferers"
RE: Supplied Ferrites all have small knot in one wire - by cutty - 2016-11-02, 11:39
  Small bug in Blue settings 83b2... elythomaslumber 8 67,440 2016-10-11, 09:25
Last Post: michael1608
  Does BLUE need shielded ferrites? Dale.Reid 4 41,434 2016-06-23, 18:37
Last Post: Eric.Wouters
