System Blue Not Working
Am I right in saying that you don't get any other LEDs cycling when you first turn on the power? From memory half turn on solid for about a second, then the other half, then the buzzer will beep indicating it's booted. After that the mode and Ethernet LEDs should light solid, along with 1pps GPS when it has a lock. If none of this happens, it's probably a firmware issue. Follow the instructions in the build document to connect the board to your PC via the mini USB port and use the ST software to manually flash a firmware file.
My PCB 19.3 did boot initially with no problems, but the firmware was too old resulting in errors in the web UI. Yours could be a similar case of a bad or incorrect initial firmware load.
Stations: 1614
System Blue Not Working - by tferoli - 2016-09-26, 23:53
RE: System Blue Not Working - by DnH2016 - 2016-09-27, 00:14
RE: System Blue Not Working - by piepants - 2016-09-27, 02:16
RE: System Blue Not Working - by tferoli - 2016-09-27, 02:24
RE: System Blue Not Working - by piepants - 2016-09-27, 03:27
RE: System Blue Not Working - by piepants - 2016-09-27, 06:06
RE: System Blue Not Working - by Tobi - 2016-09-27, 10:21
RE: System Blue Not Working - by tferoli - 2016-09-28, 18:38
RE: System Blue Not Working - by DnH2016 - 2016-09-29, 11:30
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 51,608 2025-04-19, 23:25
