System Blue Network Interface Question
(2016-09-16, 18:16)chevyman142000 Wrote: I do have a managed switch (HP Procurve). I've tried setting it to 10mb full and the port just goes disabled.
From the switch log:
Excessive CRC/% alignment errors
Half Duplex Mismatch
Excessive late% collisions
And if you set the switch to 10 Mb half duplex? The ENC28J60 is configured to be in half duplex mode as per a post further up this thread.
If you still get CRC errors I'd be getting the scope out to see what is going on with signal levels.
ENC28J60:
Pins 13 and 12 are Tx+ & Tx-, RJ45 Pins 1 & 2 Org/Wht & Org.
Pins 17 and 16 are Rx+ & Rx-, RJ45 Pins 3 & 6 Grn/Wht & Grn.
No scope, give a close examination to the joints of the components between the socket and chip, are the errors in both directions or only one?
RE: System Blue Network Interface Question - by allsorts - 2016-09-16, 22:30
  Can no longer log into System Blue Controller, Web Brouser Interface W2PJ-WX 12 40,477 2025-05-29, 12:33
Last Post: W2PJ-WX
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 51,498 2025-04-19, 23:25
  Question about web interface williammurdock 3 13,255 2024-08-10, 08:33
Last Post: DelandeC
Question Question about the antena in system Blue BlackRockShooter 7 59,523 2020-08-25, 11:23
  System Blue - Rocker Switch Question chevyman142000 5 44,296 2016-09-09, 16:57
Last Post: chevyman142000
