Fault LED indicates fault
(2016-09-15, 16:33)elythomaslumber Wrote:
(2016-09-15, 09:41)Bergkvar Wrote:
(2016-09-14, 11:00)elythomaslumber Wrote:
(2016-09-13, 09:29)LennartJ Wrote: i have the same problem but it´s the alarm red is on all the time ??
the other LED's? they ar ok
What about the Web-GUI, can you read the system status on the browser, how do i do that?
no interference.
Aehmmm, you never did any configuration on the embedded web-server  of the system?
Maybe there is a misunderstanding...
- Check your router and find out what IP adress your System Blue got
- type in the IP adress in your browser
- you should see now the WEB-GUI and all information or configuration tabs
- see also here: http://de.blitzortung.org/cover_your_area.php?session=1  ; download the manual and read beginning of page 69
- maybe you did not disable AMP1 or AMP2 if there is no antenna connected to any of the input terminals?
Good luck!
Thank i find it now its working fine now
Stations: 148, 1598, 1601
Fault LED indicates fault - by j82 - 2016-06-30, 08:55
Fault LED indicates fault - by DelandeC - 2016-06-30, 09:45
RE: Fault LED indicates fault - by j82 - 2016-07-01, 11:20
RE: Fault LED indicates fault - by LennartJ - 2016-09-13, 09:29
RE: Fault LED indicates fault - by Bergkvar - 2016-09-15, 09:41
RE: Fault LED indicates fault - by LennartJ - 2016-09-16, 12:01
RE: Fault LED indicates fault - by Tobi - 2016-09-20, 08:40
  Fault mode after big electrostatic discharges. ant01n3 1 13,837 2024-01-30, 22:55
Last Post: dupreezd
  fault led at first boot uvash 3 26,789 2021-11-18, 10:37
Last Post: aloha20
  How to get alerts of fault or missing GPS jchonig 2 21,120 2020-12-30, 18:23
  Flashing networks led Alanpenwith 1 22,101 2018-09-14, 08:44
Last Post: Polyphemus
  LED placement question SteveQlQ 6 51,188 2018-02-04, 16:14
Last Post: cernese
