System Blue Network Interface Question
(2016-09-13, 23:24)chevyman142000 Wrote: I checked the solder joints and everything looks good. I tried a different switch port and never could get a link if I did any full duplex or anything above 10mb. I'm also still seeing errors on the port, maybe because it is only running at half duplex? Not sure.
Will run 10 Mbps Half unless you have managed switch and set the port to 10 Mbps Full.
For example I am using a Cisco 2960G and can fix port speeds and duplex.
What errors are you seeing? Do you mean collisions?
Collisions are normal for 10 Mbps Half.
RE: System Blue Network Interface Question - by kevinmcc - 2016-09-16, 01:48
  Can no longer log into System Blue Controller, Web Brouser Interface W2PJ-WX 12 40,477 2025-05-29, 12:33
Last Post: W2PJ-WX
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 51,498 2025-04-19, 23:25
  Question about web interface williammurdock 3 13,255 2024-08-10, 08:33
Last Post: DelandeC
Question Question about the antena in system Blue BlackRockShooter 7 59,523 2020-08-25, 11:23
  System Blue - Rocker Switch Question chevyman142000 5 44,296 2016-09-09, 16:57
Last Post: chevyman142000
