Estimated Data Usage - System Blue
(2016-08-29, 14:58)John.Sacrey Wrote:
(2016-08-29, 14:40)Karlchen_1 Wrote: Hi,
i hope to setup a System blue as soon as i can get one - but i have a not so trivial question.
- how much bandwith will be used?
- how much data will be send /received (estimate) per month?
Tank you in advance
Greetings
Bjoern
The station will be installed in the area of Koblenz / Rhineland-Palatinate / Germany.
Hi Bjoern,
I have a System Red in the U.S. On some active days here, I've sent over 1 GB/ day. Fortunately, it doesn't happen often, but it does happen. System Blue should be about the same, possibly a little more efficient, because of the new compression ratios built into it.
Hope this helps,
John
In the last 14 hours, 1439 has sent <80 MB , approximately 108,000 signals.... typical packet  is approx. 760 bytes
RE: Estimated Data Usage - System Blue - by cutty - 2016-08-29, 16:27
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 51,466 2025-04-19, 23:25
  Setting up a new station and Data Usage questions Avery 3 35,175 2016-05-02, 00:26
Last Post: dalek
