Circuit diagram+parts list for amplifier V5.5
Hi, where can I find a circuit description and parts list, so that I can complete the amplifier PCB 5 V5? The online docs do not show the Oldies...
Regards, Uwe
Stations: 407
I've found some older documentation here: http://www.faq-blitzortung.org/index.php...artlang=de
(2014-07-13, 15:27)Tobi Wrote: I've found some older documentation here: http://www.faq-blitzortung.org/index.php...artlang=de
Thanks a lot! That will help. I am also looking for circuit diagram and parts list of PCB 6 Version 8usb, as Egon's description ends with PCB 6 V 7, which is different in layout and components (which I realized today).
Regards, Uwe
Regards, Uwe
Sorry, meanwhile I found PCB 6 V8 docs with Google's help. Its settled now. Regards, Uwe
Stations: 407
Old doc is still available there: http://www.blitzortung.org/Documents/TOA...ortung.pdf Big Grin
UweBergh, well, I know if you found the documentation using google, I could too but I was wondering if you could help me out. I’ve been looking for PCB 6 documents for quite some time now but just couldn’t manage enough time to dedicatedly sit on google and search for them. Since you have PCB 6 V8 documents, it’ll be a big help if you can share these.
circuit assembly
.pdf   TOA_Blitzortung_b.pdf (Size: 914.74 KB / Downloads: 262)
.pdf   Bestellliste_PCB5.7_PCB6.8usb.pdf (Size: 41.23 KB / Downloads: 166)
(2015-02-02, 23:23)carkifelek Wrote: UweBergh, well, I know if you found the documentation using google, I could too but I was wondering if you could help me out. I’ve been looking for PCB 6 documents for quite some time now but just couldn’t manage enough time to dedicatedly sit on google and search for them. Since you have PCB 6 V8 documents, it’ll be a big help if you can share these.
Hi,two pdf-files are attached. Regards, Uwe
Stations: 407
  System RED circuit and PCB diagram Mark.Smith 2 26,415 2018-02-03, 15:59
Last Post: Mark.Smith
  Several questions about the circuit protection that using linear power supplies Jand 3 33,530 2017-12-22, 23:03
Last Post: allsorts
  System Blue Circuit Diagrams nerd65 0 16,329 2016-06-22, 13:56
Last Post: nerd65
  Missing Parts - 47 ohm resistors gadjex 11 101,220 2014-08-18, 08:40
Last Post: RichoAnd
  Mising parts need mouser parts zendick 5 44,764 2014-07-18, 05:44
Last Post: RichoAnd
