2014-07-12, 22:19
Hi, where can I find a circuit description and parts list, so that I can complete the amplifier PCB 5 V5? The online docs do not show the Oldies...
Regards, Uwe
Regards, Uwe
Stations: 407
Circuit diagram+parts list for amplifier V5.5
2014-07-12, 22:19
Regards, Uwe
Stations: 407
2014-07-13, 15:27
I've found some older documentation here: http://www.faq-blitzortung.org/index.php...artlang=de
(2014-07-13, 15:27)Tobi Wrote: I've found some older documentation here: http://www.faq-blitzortung.org/index.php...artlang=de Thanks a lot! That will help. I am also looking for circuit diagram and parts list of PCB 6 Version 8usb, as Egon's description ends with PCB 6 V 7, which is different in layout and components (which I realized today). Regards, Uwe (2014-07-13, 22:13)UweBergh Wrote:(2014-07-13, 15:27)Tobi Wrote: I've found some older documentation here: http://www.faq-blitzortung.org/index.php...artlang=de Sorry, meanwhile I found PCB 6 V8 docs with Google's help. Its settled now. Regards, Uwe
Stations: 407
2014-07-14, 16:58
Old doc is still available there: http://www.blitzortung.org/Documents/TOA...ortung.pdf
2015-02-02, 23:23
(This post was last modified: 2015-02-09, 21:30 by carkifelek.)
UweBergh, well, I know if you found the documentation using google, I could too but I was wondering if you could help me out. I’ve been looking for PCB 6 documents for quite some time now but just couldn’t manage enough time to dedicatedly sit on google and search for them. Since you have PCB 6 V8 documents, it’ll be a big help if you can share these.
circuit assembly
2015-02-04, 00:48
TOA_Blitzortung_b.pdf (Size: 914.74 KB / Downloads: 262)
Bestellliste_PCB5.7_PCB6.8usb.pdf (Size: 41.23 KB / Downloads: 166)
(2015-02-02, 23:23)carkifelek Wrote: UweBergh, well, I know if you found the documentation using google, I could too but I was wondering if you could help me out. I’ve been looking for PCB 6 documents for quite some time now but just couldn’t manage enough time to dedicatedly sit on google and search for them. Since you have PCB 6 V8 documents, it’ll be a big help if you can share these. Hi,two pdf-files are attached. Regards, Uwe
Stations: 407
« Next Oldest | Next Newest »
| Possibly Related Threads… | |||||
| Thread | Author | Replies | Views | Last Post | |
| System RED circuit and PCB diagram | Mark.Smith | 2 | 27,048 |
2018-02-03, 15:59 Last Post: Mark.Smith |
| Several questions about the circuit protection that using linear power supplies | Jand | 3 | 34,306 |
2017-12-22, 23:03 Last Post: allsorts |
| System Blue Circuit Diagrams | nerd65 | 0 | 16,662 |
2016-06-22, 13:56 Last Post: nerd65 |
| Missing Parts - 47 ohm resistors | gadjex | 11 | 103,169 |
2014-08-18, 08:40 Last Post: RichoAnd |
| Mising parts need mouser parts | zendick | 5 | 45,833 |
2014-07-18, 05:44 Last Post: RichoAnd |
