User Name samsam
Station Number 2859
Region: Europe, UK
Thanks,
(2020-11-02, 23:34)Dave:WD7K Wrote: User Name: Dave:WD7K
User Number: 1780
Station Number: 2283
Region: North America
Station listed, Was receiving data. No longer receiving data.
Problem solved.
Thank you, Dave
User Name for Forum: uk52rob
Station Number: 2876
Region: Eurpoe/United Kingdom
User Name for Forum: Psynosaur
Station Number: 2884
User Number: 2278
Region: Africa/South Africa
station not listed in https://www.lightningmaps.org/
(2021-01-23, 14:19)Psynosaur Wrote: User Name for Forum: Psynosaur
User Number: 2278
Re: Lightningmaps.org -- You might refer to this post:
https://forum.blitzortung.org/showthread...1#pid23501
User Name FJTO
Station Number 2511
Region: Europe
User Name: werk_ag
Station Number: 1045
Region: Europe
Only have access to public forum...
User Name for Forum: MASHEP
Station Number if you have one: 2892
Region: Oceania
User Name: Art_Brown
Station 2285
USA/Caifornia
Sataion not listed on list or shown on map at https://map.blitzortung.org/#12.41/37.73743/-121.93404
Stations: 2285
(2021-03-16, 21:27)Art_Brown Wrote: User Name: Art_Brown
Station 2285
USA/Caifornia
Hello Art:
Your station DOES NOT SHOW because you are misconfigured.
You have selected 'anonymous' on your station configuration page, which prevents ANY of your station data being displayed.
You are sending signals, and they are being recorded, etc, but your data is NOT visible because of your selection.
[Image: 2285%20anon.png]
While you are changing the
Anonym: Y to  Anonym N,  please configure your antennas etc correctly.
  https://forum.blitzortung.org/showthread.php?tid=2863
Your system signals are processed as 'server's best guess' without the correct antenna configurations.
Also note you have your optional filters set so NO frequency higher than 25kHz will be processed.  Unless you have extreme noise at normal settings above 25kHz, you are NOT sending best data with the low end bandwidth only. Strongly suggest turn them off, and re-optimized your station.
As to other questions regarding data in that above thread, (tid 2863) please note  the ONLY official data is what is on the OFFICIAL site, blitzortung.org.  NO Adjunct site will present correct, up-to-the moment data, and statistics aren't computed 'officially' and will be at variance with 'officially' derived data.
User ID: 2296
Station ID: 2906
Please activate participant status in forum.
(2021-03-16, 23:59)cutty Wrote: As to other questions regarding data in that above thread, (tid 2863) please note  the ONLY official data is what is on the OFFICIAL site, blitzortung.org.  NO Adjunct site will present correct, up-to-the moment data, and statistics aren't computed 'officially' and will be at variance with 'officially' derived data.
Official or not, I am among the many participants here who find it useful. And so does @Tobi, or he wouldn't have brought it back from the dead after the fire. I'm grateful for that. (This is not to imply anything against BTO. I like it too. Smile
It's NOT useful if the data isn't correct!  Hopefully Tobi and Egon can get those databases married.... until that happens I suggest take what you see on LMO, especially with station listings and comparisons, with a grain of salt or an aspirin pill.
I fully agree that much of the data is incorrect. But perhaps this is not a good thread to expound on that. Smile
Station ID:2824
User ID:2221
May I have participant status in forum.
Hannu
(2021-05-05, 17:59)HEr Wrote: Hi,
Station ID:2824
User ID:2221
Hannu
Absolutely!  Done!
Stay Safe!
< post removed >
[EDIT: IGNORE THIS MESSAGE. STATION APPEARD ON THE LIST]
Hello from Greece.
Station not in list.
Station ID:2907
User ID:1162
Thanks in advance!
User Name: moparhead
Station Number: 2728
Region: Europe
Station  2728
Stations: 2728
Forum Operator Status not upgraded
USER PDM1964
User ID: 2304
Station Number 2922
Region... North America
Thanks!!
  Station List not showing any United Kingdom stations dgoadby 2 34,736 2019-04-15, 16:35
Last Post: dgoadby
  Removing Station 723 from list Ian.Cooke 5 58,534 2015-02-03, 20:39
Last Post: Toxic
