2018-04-12, 13:34
looks good in transparent acrylic!
2018-04-13, 22:09
I think the aluminium housing provides some shielding from the various sources of noise that we all have about us and I consider it a backward step to remove this added protection!
Brian. 1856 Vilaboa
2018-04-13, 22:14
(2018-04-13, 22:09)readbueno Wrote: I think the aluminium housing provides some shielding from the various sources of noise that we all have about us and I consider it a backward step to remove this added protection! What tests have you performed to prove that, Brian?
2018-04-14, 02:26
(2018-04-13, 22:14)mwaters Wrote:(2018-04-13, 22:09)readbueno Wrote: I think the aluminium housing provides some shielding from the various sources of noise that we all have about us and I consider it a backward step to remove this added protection! Brian, if that were necessarily the case, do you really believe I would have my "Blitz Wall' configured as in the above image, within inches of 3 large monitor screens, and within two meters of 5 operating PC Towers, routers, modems etc???? ![]() In this situation, my junk is H field Antenna, received noise... the Controllers, and E amplifer for the Reds just quietly do their thing.
My thinking exactly! Those 3 stations are performing superbly without any shielding whatsoever!
2018-04-14, 08:11
O.K. Folk's! I know absolutely nothing I am just another grumpy old fool!
Forgive/ignore my input/intrusion into this topic. My profuse apologies! We can all believe what we want to, but that does not make it true? Intuitively, if a electronic circuit has a metal case, it is better shielded than the same circuit without that case? Maybe, you have just got the settings correct to cover/mask any bad effects? Kindest regards, Brian. 1856 Vilaboa. P.S. I am never right in any of the forums that I post in! Even, when I agree with people, there is always someone that wants to disagree. I am too old to fight. So, just ignore me and I will fade into the background gracefully.
2018-04-14, 09:46
(2018-04-14, 08:11)readbueno Wrote: O.K. Folk's! I know absolutely nothing I am just another grumpy old fool! Is the used alu house grounded? I ll think that if you use the ground as provided, and connect it to the print provided it would be ok. Otherwise you should make use of the cage of Faraday so you will need to ground th ehousing - if you ask me - But hey who am I?b
Stations: 2083
2018-05-06, 00:58
I don't have a laser cutter, but I do have a 3d printer, so I'm making one that I'll be posting to thingiverse when complete.
2018-09-03, 07:56
(2018-01-08, 01:13)higherperspective Wrote: Hi all. Hi all, about the system blue housing. Does anyone has pdf files on the front and back panel from the aluminum box. In the hardware index you only find TARGET 3000 files, but my system (MAC) can not read those files. The files can be found here: http://de.blitzortung.org/Compendium/Hardware/. Thanks in advance!
2018-09-03, 17:56
Hi all,
2019-01-18, 09:54
(This post was last modified: 2019-01-18, 09:57 by AntonBurtsev.)
Hello.
I developed a housing model for 3D-print. Today upload it on the thingiverse. The link will be a little later. ![]() ![]() ![]() ![]() ![]()
2019-01-22, 08:37
Housing was upload to ThingIVerse:
https://www.thingiverse.com/thing:3364124
2020-04-02, 08:51
(2019-01-22, 08:37)AntonBurtsev Wrote: Housing was upload to ThingIVerse: Anton, Wondering if you can share the build files. I've got an earlier model board, seems the back is different. Craig.
Stations: 1679
The housing suitable for the BLUE system is a model ALUG706BU160 GAINTA to be purchased from TME for a price of €19.01. https://www.tme.eu/de/en/details/alug706bu160/enclosures-with-panel/gainta/ PCB is assembled without any modifications. Of course, the holes must be cut. I can provide CAD drawings for making holes from the front panel for sockets for interested parties and photos of the finished set. Peter ![]()
Stations: 2629
| Lightning in 3D. | mvdswaluw | 1 | 21,260 |
2020-06-09, 10:10 Last Post: scilover |
