System Blue Voltage regulator and antenna
Hello: I just received my new system Blue (Thank you Egon!) and am starting the assembly. I have two questions:
1  My board is marked PCB 20.4. Am I correct that I do NOT have to follow step 2.3 in the documentation? This is in regards to the voltage regulator extension.
2  In the description of system Red, there is a discussion on shielding the ferrite antennas, while in the System Blue documents it appears as if this is not necessary. Is this right?
Thank you,  Steve
1. Yep, that's right.
2. Shielding is not always necessary. It depends of your environement. On system BLUE, connect the shield to the GND input of the pre-amp if needed.
Wink
DelandeC: Thank you very much for the reply. I hope to get to the testing phase in the next few days.
(2017-08-11, 15:05)SteveQlQ Wrote: Hello: I just received my new system Blue (Thank you Egon!) and am starting the assembly. I have two questions:
Thank you,  Steve
Shielding of Ferrite Antennas is not necessary :-)
/Richo
  Blue e-field antenna question llowrey 2 21,438 2021-07-06, 14:34
Last Post: llowrey
  blue ferrite / loop antenna connection? MTO-Mareuil 1 18,589 2020-10-20, 11:43
  GPS antenna SYSTEM BLUE ! IK1TTD 9 74,192 2020-06-03, 12:16
Last Post: GJ7DNI
  Blue System: PreAmp & Antenna Questions BassJohn 5 44,871 2018-02-28, 08:41
Last Post: BassJohn
  Blue H field Ferrite antenna in L or Delta shape? nellyt 8 73,632 2017-03-30, 03:06
Last Post: Mike6158
