H-field pre-amplifier PCB and ferrite antennas
For the system blue H-field pre-amplifier PCB - a few questions:
1.  Do the ferrites connect between just the a and b ports with the ground port left unconnected unless additional shielding is needed?
2.  Is there any polarity to the ferrites - I see references to one enameled wire with a knot being + or is this for the old system only.
3.  For ferrite antennas do the PCB jumpers need to be soldered (closed).
Thanks in advance!
A single ferrite antenna will connect to A1 and A2, and the ground is there for shielding if you decide to shield the antenna.
Polarity does not matter.
No the PCB jumpers do not need to be soldered closed.
  Locating ferrite antennas inside metal shed? Geewizard 1 16,694 2025-07-26, 02:25
Last Post: davidmc36
  Optimizing H-Field Antennas for Urban Installations WonderNomad 2 18,936 2025-06-21, 18:59
Last Post: GeezerD
  New pre-amplifier?? Salminen 4 30,866 2023-04-26, 10:24
Last Post: hazelnut
  home made ferrite antennas opadavis2 10 81,976 2017-07-23, 19:34
Last Post: pasense
  Blue H field Ferrite antenna in L or Delta shape? nellyt 8 76,498 2017-03-30, 03:06
Last Post: Mike6158
