I'm finding I'm getting exactly 100 triggers per second on the H field antenna and I think it's down to house wiring as turning it so that it's 45 degrees off parallel with the x and y axis of my house reduces the noise. The auto amplitude filter is effective and cancelling out +/-47 and +/- 141mV
Antenna is a coaxial möbius with a 50 turn transformer. Settings below. Any thoughts?
Amplifiers
![[Image: new.png]](http://192.168.1.222:8080/img/new.png)
Amplifier 1 - H0![[Image: edit.png]](http://192.168.1.222:8080/img/edit.png)
Amplifier 2 - E0![[Image: edit.png]](http://192.168.1.222:8080/img/edit.png)
ADC
- ModeAutomatic, Noise Adaption, Amplitude Filter
- SignalsReceived: 396404, Good: 14969, Sent: 13692
- Signal RateLast second: 100, Last 60s: 99.6
- ErrorsNo GPS: 0, Overflow: 0
- StatusNormal
- Server , Region 1
10.6MByte, 3% Compr., 13692 Packets, 812Bytes each
Amplifiers
Amplifier 1 - H0
- Channel A
- Trigger-37mV/91mV, reached 20 times in last 15m, 54s
- Gains10 * 10 * 40 = Total Gain 4000 | Relative Gain 6349 (99%)
- Noise47mVpp
- Lowpass Filter30.5kHz
- Auto Ampl.Filter amplitudes around 47mV
Amplifier 2 - E0
- Channel A
- Trigger-44mV/82mV, reached 95291 times in last 15m, 54s
- Noise35mVpp
- Auto Ampl.Filter amplitudes around -141, -47, 141mV
ADC
- Sampling per InputResolution: 12bits, Period: 666ns = 500.0kSPS, Time: 2000ns
- ADC1
- Input1Amp-Channel 3 , Offset 27mV, no Trigger
- Input2Amp-Channel 4 , Offset 19mV, Trigger -63mV/63mV
- ADC2
- Input1Amp-Channel 2 , Offset 24mV, Trigger 0mV/0mV
- Input2Amp-Channel 3 , Offset 27mV, no Trigger
- ADC3
- Input1Amp-Channel 1 , Offset 27mV, Trigger -64mV/64mV
- Input2Amp-Channel 2 , Offset -169mV, no Trigger
