System Blue Order Status 12. August 2016
Can you please elaborate about how we can purchase the raspberry pie version. I am facing confusion in this.
(2017-03-05, 13:15)lalalatifa007 Wrote: Can you please elaborate about how we can purchase the raspberry pie version. I am facing confusion in this.
there is no raspberry version for this project. Today only the blue kit is available.
Cutty, is there not a situation where one may want to maximise detection distance? For example when you run a station which is far away from other stations, maybe on an rather isolated island?
He is talking about quality of data. I have seen my detector catching strikes 2500 km away.
Further away you have to contend with local noise, weak signals, sky waves, and other problems.
Really need more detectors if you are on an island, look at Hawaii for example.
Would be neat if the universities stepped and placed station at some of their remote campuses.
How much noise will there be on the outskirts of the city? Will the military airport influence?
Stations: 1684, 2917
(2017-03-07, 19:28)malyan Wrote: How much noise will there be on the outskirts of the city? Will the military airport influence?
No one here can answer that.
May a lot. Maybe minimum.
Maybe None.
Blitzortung is "standard"... it's the environment that's different, and changing hourly, seasonaly.
This is NOT plug and play, or predict from a map.
Here:
http://www.wxforum.net/index.php?topic=20439.0
The red H-field LED is off.
From what for it can be?
How do I fix the problem?
(2017-03-21, 00:31)malyan Wrote: The red H-field LED is off.
Are you using agood shielded network cable to the H preamp?
The H preamp cable is plugged in to the correct Net Connector?
(2017-03-21, 00:45)безнравственная женщина Wrote:
(2017-03-21, 00:31)Malyan Wrote: Красный Н-поле СИД.
Из чего за это может быть?
Как решить эту проблему?
Вы используете Agood экранированный сетевой кабель к H предусилитель?
H предусилитель кабель подключен к нужному разъему Net?
Как хорошая феррита антенна должна появиться в веб-интерфейсе?
КАКИЕ ценности?
1684 станция
Hi Malyan,
Can you start a new topic over in Station Hardware and Firmware > Troubleshooting? Giving a summary of your problems.
The red H field pre-amp LED going out shouldn't happen and helping to find the cause might be a long discussion. This forum and topic isn't really the place for that discussion.
Reply here when you have otherwise it might be a while before I notice.  B-)
Often the connection to the Internet (router) is lost how to fix it?
Was #9 or #6 yesterday.... Been watching for the email to come through....
Today, I've dropped to the very bottom....
No notice to place my order or anything.... Did I mess up?
Stations: 1961
(2017-03-24, 18:47)KY5G Wrote: Was #9 or #6 yesterday....  Been watching for the email to come through....
I had the same thing happen.  I received my invitation a few hours later.
Brian ,N7QJB
OK...  I am confused for sure....
The email that was #6 or 9 yesterday and #1597 today is KY5G@montac.com.
I have looked through my email files and no email is in inbox, junk/spam, or trash with an invitation to order.
Could it please be resent?
Stations: 1961
Can't read the German error text, but will email you with address alternatives...
EDIT:  Email alternatives sent.  Thank you so much for the help and doing this project.
EDIT #2 2119 UTC 03/26/17 - Email delivery delayed to info@blitzortung.org...
Stations: 1961
Can you ping blitzortung.org?
What does a tracert show for blitzortung.org?
This post has been deleted.
Hi! How do I place an order for two System Blue? Plan to install one near Moscow region at coordinates 55.874396,36.911103 and another 60km toward south.
(2017-04-25, 20:58)dagnazza Wrote: Hi! How do I place an order for two System Blue? Plan to install one near Moscow region at coordinates 55.874396,36.911103 and another 60km toward south.
It's the same as placing an order for one System Blue. You have to sign to the waiting list and if you're lucky, in a half year's time (at least) there will be your turn. Egon will contact you and ask you to place your order. You'll have to be really patient on this one.
I'm looking for a Russian-speaking member. Need help buying and customizing. South Ukraine.
Есть ли в сообществе русскоязычные участники, которые имеют опыт покупки сборки и отладки устройства? Насколько проблематично получить компоненты в Украину?
  How to order system blue-basic? Kellogs 3 56,139 2025-04-20, 00:09
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 51,549 2025-04-19, 23:25
  Can I order? larryf 1 40,487 2024-09-07, 20:55
Last Post: gerbold
  System Blue order status (10.3.2020) Egon 33 337,842 2023-11-29, 21:57
  Issue starting Sunday August 1st at 13.00 PA4EME 2 52,381 2021-08-07, 23:08
Last Post: orion_jb2001
Users browsing this thread: 17 Guest(s)
