System Blue - Digital Filter Pin 1 Identification
#21
(2016-09-14, 20:30)kevinmcc Wrote:
(2016-09-14, 19:18)Polyphemus Wrote: Hello,
I added one filter IC for the E-amp channel, I soldered J0, but I don't see the extra filters menu... What am I doing wrong?
You may have to update the firmware.
Older versions did not have filter menu.
Hi Kevin,
Thank you for your reply. I am already on the latest beta firmware of System Blue, 8.1, but no luck yet.
#22
Hi Kevin,
If you installed the filters correctly and jumped J0, you should be seeing the filter option for channels you have set to normal.
Maybe you can take picture of circuit board?
#23
Do I have to solder IC's for all 4 channels? Currently I'm only using the E-amp, because I'm in the process of making my H-field antenna's. So I only soldered the IC for the E-amp... I disabled the H-amps in the config.
#24
No, there is an information somewhere in the manuals that you should start with one IC and then check if it was succesfully and if it helps.
I did not solder my 2 chips at the moment but I don't need more.
73 de Hartmut / DK5LH
Stations: 1582
#25
They can be mounted in random order and from one to four pieces.
The CPU tests J0, it is shorted, it sends clock signals, filter-ic or not Smile
/ Richo
#26
Here are some photo's of my setup, I do not see what I'm doing wrong  Huh
http://imgur.com/a/CXisS
#27
(2016-09-18, 13:19)Polyphemus Wrote: Here are some photo's of my setup, I do not see what I'm doing wrong  Huh
Looks correct.
Could be jumper is bad, or a defect with the board.
RichoAnd what happens with the CPU connection is floating?
#28
Hi everybody,
I have to apologize, the filter section is only visible when Remote Control mode is set Manual mode. I found it by accident... Sorry for the confusion...
#29
(2016-09-20, 14:57)Polyphemus Wrote: Hi everybody,
I was just going to post that. Tongue
I was getting interference and testing automatic and noticed filters were gone.
  Filter orientation - BLUE KY5G 2 26,694 2017-08-14, 05:03
Last Post: KY5G
  Digital lowpass filter radiofarol 3 35,636 2017-06-10, 22:23
Last Post: radiofarol
