New station confusion
Just switched my new station on over the weekend. The ID is 1238. Status from the controller says "Normal", both amps (E + H) show noise levels and gain jumping around (automatic mode). However, the signals page shows nothing. All channels are checked "Display" but no traces appear. Do I need to do something to enable that?
The amplifier status for all input channels shows the trigger as disabled. Is that bad?
Also, on the controller's status page, in the section for remote configuration, my station ID (1238) is shown as a link but that link goes to a nearby station, not mine
Thanks for any help!
Stations: 1238
(2014-11-10, 07:29)sparkyeric Wrote: Just switched my new station on over the weekend. The ID is 1238. Status from the controller says "Normal", both amps (E + H) show noise levels and gain jumping around (automatic mode). However, the signals page shows nothing. All channels are checked "Display" but no traces appear. Do I need to do something to enable that?
Welcome to Blitzortung! Can you tell us where you are located? Interestingly, when I click on your id at the bottom of your message, I wind up looking at my station information. So, something isn't working correctly. Did you use the build and set-up documents that have been developed for RED systems? I would suggest not using "Automatic" mode and for you to learn to use the "Manual" mode. It will give you a better understanding of just how the system works.
EDIT: Looking more closely at your user profile, it appears you are in the Seattle Washington area. Your UserID is 1114 and your StationID is 1238. I can find no historical data from your station so it apparently has never been on-line. Once you start sending valid data, you will begin to see your data history.
Stations: 808
I am closing this thread as the OP has posted the same question on the Internal forum. Please use the following link to reference any suggestions for repair of this problem.
http://www.blitzortung.org/Webpages/inde...hp?tid=961
Stations: 808
